Allis Chalmers 912 lawnmower
hunter321 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote hunter321 Quote  Post ReplyReply Direct Link To This Post Topic: Allis Chalmers 912 lawnmower
    Posted: 13 May 2023 at 7:29pm
I am fixing a mower for my uncle and need to know everything that could be wrong with it
He said engine problems
Post Options Post Options   Thanks (0) Thanks(0)   Quote AC720Man Quote  Post ReplyReply Direct Link To This Post Posted: 13 May 2023 at 7:44pm
Until you start diagnosing what is wrong not sure we can be of help. A lot of things can cause engine issues, once you get it make sure it has fire to the spark plug first. And go from there.
Gary View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Gary Quote  Post ReplyReply Direct Link To This Post Posted: 14 May 2023 at 4:44am
Start with the basics.
A Gas Engine needs 3 things to run: Fuel - Air - Spark
Like 720 says, make sure it has spark. Then move on.
G
https://www.tractordata.com/lawn-tractors/000/1/5/154-allis-chalmers-912.html
This gentleman Zippo Varga is very knowledgeable about Allis / Simplicity Tractors
https://www.youtube.com/results?search_query=allis+912+engine
Edited by Gary - 14 May 2023 at 7:54am
Post Options Post Options   Thanks (0) Thanks(0)   Quote hunter321 Quote  Post ReplyReply Direct Link To This Post Posted: 14 May 2023 at 5:29pm
I need to pull the engine
How do I do that
Gary View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Gary Quote  Post ReplyReply Direct Link To This Post Posted: 14 May 2023 at 6:28pm
For the past year you have been on the Forum requesting help with a dismantled Engine in an Allis D-12.
Now your starting another project regarding a Allis Model 912 Engine.
and you ask the simplest of questions !
   How do I remove the engine ?
How the hill do you think you would remove the Engine ?
Unbolt the appropriate bolt, nuts, brackets, wiring, cables etc that are attaching the Engine to the Tractor and then lift it out.
What am I missing here ?
G
Leadoff View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Leadoff Quote  Post ReplyReply Direct Link To This Post Posted: 14 May 2023 at 7:27pm
hunter321
There are many excellent YouTube videos on how to do whatever project on repairing/tuning Garden Tractors.  I have found Zippo Varga to be one of the best, and he seems to specialize in Allis Chalmers and Simplicity(identical to Allis Chalmers - same ownership/manufacturer).  He explains lots of details, and speaks at a level most owners can understand
Here is a link to one of his recent vids.  The second link is his YouTube video library
Good luck
PS  he has several videos showing in great detail how to remove trhe engine
1963 D17D Series III. 1965 D15 Series II. 1965 D17 Series IV. 1975 185. 1978 716H. 1979 716H. 1965 780 Harvester/1R&DC. 1957 Model 73 SC 4 Furrow Plow
Post Options Post Options   Thanks (0) Thanks(0)   Quote hunter321 Quote  Post ReplyReply Direct Link To This Post Posted: 15 May 2023 at 1:43pm
I got the engine pulled and the piston disconnected at the bottom but it won't pound out.
Also the flywheel seems to be seized.
So far it needs gaskets possibly piston rings
Post Options Post Options   Thanks (0) Thanks(0)   Quote hunter321 Quote  Post ReplyReply Direct Link To This Post Posted: 19 May 2023 at 9:49am
I looked up the mower on tractor data and it said it has a Kohler k301s but I can only find the k301
Gary View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Gary Quote  Post ReplyReply Direct Link To This Post Posted: 19 May 2023 at 1:00pm
I believe the S means it has a Factory Starter.
G
Post Options Post Options   Thanks (0) Thanks(0)   Quote hunter321 Quote  Post ReplyReply Direct Link To This Post Posted: 19 May 2023 at 1:18pm
Ok
So I can find gaskets for the 301
Post Options Post Options   Thanks (0) Thanks(0)   Quote hunter321 Quote  Post ReplyReply Direct Link To This Post Posted: 10 Jun 2023 at 4:39pm
Ive looked all over for the correct way to wire the coil and can't find it
How do I wire it
Post Options Post Options   Thanks (0) Thanks(0)   Quote hunter321 Quote  Post ReplyReply Direct Link To This Post Posted: 12 Jun 2023 at 10:21am
I have power to the points and the positive and negative points on the coil but no spark
Any help Is greatly appreciated
HudCo View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote HudCo Quote  Post ReplyReply Direct Link To This Post Posted: 12 Jun 2023 at 10:08pm
keyed battery power  to the coil from the coil to points points must open and close and the contacts must be smooth and clean and gapped and condensor needs to be good . most all of the k 301 stuff fits
Post Options Post Options   Thanks (0) Thanks(0)   Quote hunter321 Quote  Post ReplyReply Direct Link To This Post Posted: 24 Jun 2023 at 9:14am
I am looking for a cheap head for the k301 any suggestions on where to get one
Post Options Post Options   Thanks (0) Thanks(0)   Quote hunter321 Quote  Post ReplyReply Direct Link To This Post Posted: 10 Jul 2023 at 8:18am
The mower suddenly lost spark
Post Options Post Options   Thanks (0) Thanks(0)   Quote hunter321 Quote  Post ReplyReply Direct Link To This Post Posted: 17 Jul 2023 at 12:30pm
Does anyone have a wiring diagram for the mower
I am not Shure what I am looking for
This page was generated in 0.119 seconds.
