correct 7000 weights
Darb210 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Darb210 Quote  Post ReplyReply Direct Link To This Post Topic: correct 7000 weights
    Posted: 13 May 2023 at 3:39pm
hey guys, I have a 7000 black belly, should the suitcase weights be the thick or thin to be correct??  Thanks!
Post Options Post Options   Thanks (0) Thanks(0)   Quote Darb210 Quote  Post ReplyReply Direct Link To This Post Posted: 13 May 2023 at 3:40pm
oh, and how many make a full rack??
Lynn Marshall View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Lynn Marshall Quote  Post ReplyReply Direct Link To This Post Posted: 13 May 2023 at 7:14pm
I believe that it uses 10 of the thick weights on the standard rack.
plummerscarin View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote plummerscarin Quote  Post ReplyReply Direct Link To This Post Posted: 13 May 2023 at 9:21pm
14 of the thin ones?
Unit3 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Unit3 Quote  Post ReplyReply Direct Link To This Post Posted: 14 May 2023 at 4:35am
Of the thin, 15 & 21
Of the thick, 10 & 14
Wes (VA) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Wes (VA) Quote  Post ReplyReply Direct Link To This Post Posted: 14 May 2023 at 9:38am
Thin on the red frame, thick on the black frame.  Weight racks are the same and you can swap heavy weights on a red frame and vice versa.  Not sure, but you could probably blend them on the same rack, just as long as your locks get tight.
Post Options Post Options   Thanks (0) Thanks(0)   Quote DrAllis Quote  Post ReplyReply Direct Link To This Post Posted: 14 May 2023 at 10:33am
Thin weights are 62 lbs x 15 is 920 lbs plus the heavy weight rack and keepers. We always called that a thousand pound set-up. The thick weights are 90 - 92 lbs each x 10 also comes out to 900 to 920 lbs total cast iron using the same weight rack.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Lynn Marshall Quote  Post ReplyReply Direct Link To This Post Posted: 14 May 2023 at 11:29am
I'm not too sure that the thick weights weren't used on the late maroon tractors?? I also don't think it would be wise to use the extended set on a standard front axle 7000.
Kevin210 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Kevin210 Quote  Post ReplyReply Direct Link To This Post Posted: 14 May 2023 at 7:37pm
I have 9 thin weights if interested.
Post Options Post Options   Thanks (0) Thanks(0)   Quote DrAllis Quote  Post ReplyReply Direct Link To This Post Posted: 14 May 2023 at 9:55pm
I too remember the thick weights on the later 1976 model maroon belly tractors. They used to kind of brag that the thin weights were easier to handle at 62 lbs, but I'm sure the 92 lb weights in the end cost less per pound to produce.
