Loader tires 6080 recomendations
ssefick View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote ssefick Quote  Post ReplyReply Direct Link To This Post Topic: Loader tires 6080 recomendations
    Posted: 12 May 2023 at 7:11pm
I have 3 ribbed agg tires on the 6080. Are there any recommendations for loader tires?
DanWi View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote DanWi Quote  Post ReplyReply Direct Link To This Post Posted: 12 May 2023 at 8:16pm
I like 11L 15 implement floats on my 200 with the loader only other field work it sees is pull 500 gallon sprayer and a little hay raking.
Michael (WI) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Michael (WI) Quote  Post ReplyReply Direct Link To This Post Posted: 13 May 2023 at 6:23am
If they are rear bias tires, with my hills I go with loaded tires with tubes.  My 6080 is a FWA which has radials up front so I go with unloaded so they can better grip and use a rack of font steel weights.
IBWD MIke View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote IBWD MIke Quote  Post ReplyReply Direct Link To This Post Posted: 13 May 2023 at 7:41am
My 6080 has 10.00x16 four ribs on it. That's the way Dad ordered it back in 84. I'm going to guess the 175 had 9.5lx15's. It had 18.4x28's on the back. I always thought it looked really tough. Both tractors were bought with loaders in mind.
The 856 I bought last year came with a TA 46 on it. also has 10.00x16's.
Post Options Post Options   Thanks (0) Thanks(0)   Quote ssefick Quote  Post ReplyReply Direct Link To This Post Posted: 13 May 2023 at 9:51am
It is not fwa. Has squishy agg tires. Not used much, but when needed the tires almost bottom out. Will do field and farm loader work.
