170 value
Dave A View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Dave A Quote  Post ReplyReply Direct Link To This Post Topic: 170 value
    Posted: 16 Oct 2010 at 9:53am
looked at a AC170 with loader.  Seemed in great shape new rubber, paint fair, Ran good. is it worth 5K. And what should I look for
Play the game for more than you can afford to lose... only then will you learn the game.
Winston Churchill
Post Options Post Options   Thanks (0) Thanks(0)   Quote Tracy Martin TN Quote  Post ReplyReply Direct Link To This Post Posted: 16 Oct 2010 at 10:08am
Front pump or rear side mounted pump? Brakes are a pain. Check wear on front end because of loader. Check tranny also for gear jumpout.See if loader has been repaired at uprights if it is an AC loader. If sound tractor, that a real deal on the price. HTH Tracy Martin
Eric[IL] View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Eric[IL] Quote  Post ReplyReply Direct Link To This Post Posted: 16 Oct 2010 at 2:59pm
All that Tracy said.  Check the front end pivot under the middle of the axle for wear.  Sometimes a new bushing will fix?  Any charging electricity routes thru the voltmeter in the dash.  You'll be jumping a dead battery until finding it.  Check the engine exhaust manifold gaskets for leaking.  $5000 would be a great price if the loader is a AC 500 fully hydraulic type.  The 170s hyd controls to the right of the seat are very handy with that loader.
acdave63 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote acdave63 Quote  Post ReplyReply Direct Link To This Post Posted: 16 Oct 2010 at 8:59pm
is it a diesel or gas
Post Options Post Options   Thanks (0) Thanks(0)   Quote Dave A Quote  Post ReplyReply Direct Link To This Post Posted: 17 Oct 2010 at 6:56am
gas. runs nice. just gun shy when spending $$$
Winston Churchill
Stan IL&TN View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Stan IL&TN Quote  Post ReplyReply Direct Link To This Post Posted: 17 Oct 2010 at 8:00am
Make sure it will not jump out of any gears while driving it.  Make sure the amp meter shows a positive charge.  Make sure all the hydraulics on the loader work smooth and that the 3-point arms raise and lower as they should.  I think $5000 is a steal for a 170 with a loader.  Buy it!
Edited by Stan IL&TN - 17 Oct 2010 at 8:02am
1957 WD45 dad's first AC
1968 one-seventy
1956 F40 Ferguson
Claus View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Claus Quote  Post ReplyReply Direct Link To This Post Posted: 17 Oct 2010 at 8:55am
If it's anything like mine or the others I have been around probably the best $5,000. you ever spent.
