7040 hydraulic remote valve acting up
Blustery Knoll Farm View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Blustery Knoll Farm Quote  Post ReplyReply Direct Link To This Post Topic: 7040 hydraulic remote valve acting up
    Posted: 11 May 2023 at 10:35pm
Wouldn't unfold my rotary hoe, but hydraulic top link worked fine. Switched hoses and then it'd unfold but the hydraulic top link would only extend.
So... Top set of couplers (remote lever closest to seat) works totally fine. Bottom couplers (lever farthest from the seat) only will run a ram one way.
I tested pressures and the right port on the bottom remote will peg a 5000 psi gauge in the raise position and not return to zero unless put in float. Reads 2000 psi in the lower (forward level position) checked in the left port. Any ideas where to start troubleshooting?
Ron(AB) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Ron(AB) Quote  Post ReplyReply Direct Link To This Post Posted: 11 May 2023 at 11:44pm
Cables are out of adjustment or worn out...how much slop is there when you move the lever?
405, 7000, 7050, 8050, 8070, L3, 2300 & 2600 disk
Post Options Post Options   Thanks (0) Thanks(0)   Quote Blustery Knoll Farm Quote  Post ReplyReply Direct Link To This Post Posted: 11 May 2023 at 11:57pm
A couple inches of slop in the handle.
Post Options Post Options   Thanks (0) Thanks(0)   Quote DrAllis Quote  Post ReplyReply Direct Link To This Post Posted: 12 May 2023 at 5:51am
The couplers usually are left is lift.....right is lower. Anyway I do not see how it is possible to read 5,000 psi anywhere when the pump only makes 2500 psi. So, quit using that valve until you figure it out. Test pump output at the tee cap on the side of the PTO valve. 2500 psi any lever activated and 350 to 600 psi at rest. 5000 psi should have exploded the pump by now. DID THIS VALVE EVER WORK RIGHT ??
8070nc View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote 8070nc Quote  Post ReplyReply Direct Link To This Post Posted: 12 May 2023 at 7:15am
How did the compensator let pressure go that high
1984 80780
1957 D14
DES 300 with 25000 engine
616 tractor
Post Options Post Options   Thanks (0) Thanks(0)   Quote Blustery Knoll Farm Quote  Post ReplyReply Direct Link To This Post Posted: 12 May 2023 at 10:10am
Dr. Allis, that remote worked fine last week. Used that remote for the marker/fold and the one that's still working properly for the lift circuit on my corn planter last week. It is possible that there's something wrong with my gauge, but it has worked fine before.
One other bit of info. When the 3 point is in the partially raised position, pulling the non working remote lever back causes the 3 point to creep up a little.
Post Options Post Options   Thanks (0) Thanks(0)   Quote DrAllis Quote  Post ReplyReply Direct Link To This Post Posted: 12 May 2023 at 12:33pm
In the beginning of your story, I would have said you have a bad coupler(s) on the tractor. Then, you threw in this 5,000 psi claim, which I frankly can't believe. The 3-point is fine.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Blustery Knoll Farm Quote  Post ReplyReply Direct Link To This Post Posted: 12 May 2023 at 3:48pm
Thanks for the help. I investigated my gauge and the needle is loose, so if I had it at a specific angle, once it passed 1500 psi it'd go all the way around. So you are right on both counts. My gauge is faulty and I found one of the couplers has a poppet that doesn't spring back.
I swapped on a generic one and it works fine now.
Can the originals be rebuilt or bought new at a reasonable price? I'd like to keep the original lever release if economical but otherwise I'll just swap on an aftermarket pair.
Post Options Post Options   Thanks (0) Thanks(0)   Quote SteveM C/IL Quote  Post ReplyReply Direct Link To This Post Posted: 12 May 2023 at 10:39pm
define reasonable....shoup catalog has Pioneer lever couplers $260 one pair.
Post Options Post Options   Thanks (0) Thanks(0)   Quote 8070nc Quote  Post ReplyReply Direct Link To This Post Posted: 13 May 2023 at 4:43am
Just got two 9500 series pioneers from blains farm and fleet for 189.00 apiece
1984 80780
1957 D14
616 tractor
ryan(IN) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote ryan(IN) Quote  Post ReplyReply Direct Link To This Post Posted: 13 May 2023 at 4:24pm
That coupler is still readily available from AGCO.  72512838 cost is around 90 bucks.  You have to use a spacer 70269167 to make it work.  Spacer is around 40.  I would not put the lever couplers on.  Get these from AGCO and it will work correctly again.  Those lever couplers leak after awhile and can be a pain.
ryan
1984 8070 FWA,1979 7060,1975 7040,1971 190,1960 D-17D,1957 D-14, 196? D-19G, 1975 5040,1971? 160,1994 R62
Post Options Post Options   Thanks (0) Thanks(0)   Quote SteveM C/IL Quote  Post ReplyReply Direct Link To This Post Posted: 13 May 2023 at 10:09pm
HMMM,there's a lot I don't know.What do mean when you say "original lever release". Is that the type my 83 8070 has which is a flat metal piece you push to hook/unhook hyd hose coupler? My 84 8070 has a lever to flip to hook up under pressure. It appears to be what those Pioneer 9500's are. I mistakenly called that a "lever release" because the lever has nothing to do with releasing. I prefer this later style.
Post Options Post Options   Thanks (0) Thanks(0)   Quote DrAllis Quote  Post ReplyReply Direct Link To This Post Posted: 14 May 2023 at 5:53am
1983 8000 series is the same as any 7000 series. Your later 8000 series is the latest and last offering from A-C considered lever release style.
Post Options Post Options   Thanks (0) Thanks(0)   Quote 8070nc Quote  Post ReplyReply Direct Link To This Post Posted: 14 May 2023 at 8:58am
Ive got one 8070 with the original style and one with the later lever style. I like the later lever type because if something accidentilly gets unhooked with a little pressure on it I dont have figure out a way to pop the ball in the end to get pressure off and spray fliud everywhere
1984 80780
1957 D14
616 tractor
Post Options Post Options   Thanks (0) Thanks(0)   Quote 8070nc Quote  Post ReplyReply Direct Link To This Post Posted: 14 May 2023 at 8:59am
Fluid
1984 80780
1957 D14
616 tractor
