AC Grader project
Lainman View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Lainman Quote  Post ReplyReply Direct Link To This Post Topic: AC Grader project
    Posted: 10 May 2023 at 11:05am
Old AC D Grader.  I'm needing a water pump that'll fit this machine.  Any help from y'all would be greatly appreciated.  I'd like to give this thing another chance at life.
  • Distance from bolt face of the water pump to the radiator is ~8.5"
  • Distance from bolt face of the water pump to the belt groove is ~4.5"
  • Water pump is a three-bolt type
  • Stamp on engine is WD 235548GA
  • Tag on machine shows D-4898
Post Options Post Options   Thanks (0) Thanks(0)   Quote Lainman Quote  Post ReplyReply Direct Link To This Post Posted: 10 May 2023 at 11:25am
DonBC View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote DonBC Quote  Post ReplyReply Direct Link To This Post Posted: 10 May 2023 at 1:47pm
It should have the very common G226 engine also used in one of AC's most popular farm tractors so a new water pump should be readily available.
Post Options Post Options   Thanks (0) Thanks(0)   Quote SteveM C/IL Quote  Post ReplyReply Direct Link To This Post Posted: 11 May 2023 at 12:02am
Get a pump for a WD tractor.
fivehands View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote fivehands Quote  Post ReplyReply Direct Link To This Post Posted: 08 Jun 2023 at 2:28pm
Wow!Shocked
This page was generated in 0.281 seconds.
