7040 Alternator
Red Bank View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Red Bank Quote  Post ReplyReply Direct Link To This Post Topic: 7040 Alternator
    Posted: 08 May 2023 at 9:17pm
Looking for an alternator for a 7040. Has a Wilson 90-01-3081 on it currently(Delco Remy style). Does anyone know where I could possibly get a one wire alternator with the tach terminal on it? Thanks in advance.
Post Options Post Options   Thanks (0) Thanks(0)   Quote steve(ill) Quote  Post ReplyReply Direct Link To This Post Posted: 08 May 2023 at 9:33pm
something like this ? ............ pulley diameter is important to get right rpm indication.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Red Bank Quote  Post ReplyReply Direct Link To This Post Posted: 08 May 2023 at 9:40pm
Steve, yes that may work , thanks for finding that I looked at their website and couldn’t find it, I will have to use my old pulley probably because it’s a two groove pulley.
ryan(IN) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote ryan(IN) Quote  Post ReplyReply Direct Link To This Post Posted: 09 May 2023 at 5:54am
Why do you want a 1 wire?
ryan
1984 8070 FWA,1979 7060,1975 7040,1971 190,1960 D-17D,1957 D-14, 196? D-19G, 1975 5040,1971? 160,1994 R62
Gary Burnett View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Gary Burnett Quote  Post ReplyReply Direct Link To This Post Posted: 09 May 2023 at 6:43am
DB has the alternators with the double pulley,very good company BTW.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Red Bank Quote  Post ReplyReply Direct Link To This Post Posted: 09 May 2023 at 7:15am
I want a one wire because right now the keyed ignition wire going to the two wire plug on the alternator does not have power on it at all, so what I have been doing is cranking tractor and then jumping across the two terminal plug to excite the alternator. I could run a new wire from the ignition switch to the alternator but one wire alternator kinda makes everything easy
Post Options Post Options   Thanks (0) Thanks(0)   Quote Steve in NJ Quote  Post ReplyReply Direct Link To This Post Posted: 09 May 2023 at 8:50am
Take a visit to our Website and read about 1 wire Alts vs 3 wire Alts. There's a lot more information there than "easy".  Especially on larger Tractors that have more current usage up at the dash...
If you go down the header to "More" a drop down window appears. You want to click on more Technical Info. Roll down to the Alternator information. Makes for a good read.
Steve@B&B
bb-customcircuits.com
