185 oil pressure gauge install
sparky View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote sparky Quote  Post ReplyReply Direct Link To This Post Topic: 185 oil pressure gauge install
    Posted: 03 May 2023 at 7:30pm
I’m wanting to add an oil pressure gauge to my 185 and wanted some ideas for installation and location. The dash on my 185 is Full. Thanks in advance.
Post Options Post Options   Thanks (0) Thanks(0)   Quote AC720Man Quote  Post ReplyReply Direct Link To This Post Posted: 03 May 2023 at 9:35pm
Post Options Post Options   Thanks (0) Thanks(0)   Quote AC720Man Quote  Post ReplyReply Direct Link To This Post Posted: 03 May 2023 at 9:39pm
I did this on my 190XT, it’s easy to see at a quick glance. I posted a list of materials on my original post a few years ago. I teed it off the oil pressure sending unit.
Edited by AC720Man - 03 May 2023 at 9:41pm
JC-WI View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote JC-WI Quote  Post ReplyReply Direct Link To This Post Posted: 04 May 2023 at 6:52am
Here is what I did to a 170.
https://www.allischalmers.com/forum/uploads/242/170_tach.JPG
 Make sure you use copper or steel tubing. Almost ruined a 190 by using the plastic tubing the gauge kit came with... and worse, the second time.... Even worse when the third line decided to take a crap. That is when I decided I better use something else other than plastic gauge kit tubing.
 I also keep the oil pressure light too, just relocate that up higher. Don't see it in the picture above because it hadn't had the hole drilled for it at the time.
Post Options Post Options   Thanks (0) Thanks(0)   Quote SteveM C/IL Quote  Post ReplyReply Direct Link To This Post Posted: 04 May 2023 at 12:42pm
There was room on dash plate on my 220 for another hole so I cut one and added oil pressure gauge. Fuel gauge is on the tank. 220 only has temp on rt and ammeter on left plus idiot light which I kept.
Post Options Post Options   Thanks (0) Thanks(0)   Quote AC720Man Quote  Post ReplyReply Direct Link To This Post Posted: 06 May 2023 at 9:33am
I never use plastic line on gauges for that reason. They sell the copper kit at Advance auto and it fits the AGCO oil pressure gauge. I also added that same gauge combo on my 160.
Edited by AC720Man - 06 May 2023 at 9:34am
Post Options Post Options   Thanks (0) Thanks(0)   Quote sparky Quote  Post ReplyReply Direct Link To This Post Posted: 06 May 2023 at 10:51am
Is there a certain part # on the Advance Auto kit?
Post Options Post Options   Thanks (0) Thanks(0)   Quote AC720Man Quote  Post ReplyReply Direct Link To This Post Posted: 07 May 2023 at 9:57pm
I didn’t find the part number during a brief look on line. I know they carry it, It’s made by Bosch. Comes with the copper line, Ferrell’s, and some fittings. Around $15 the last time I bought one.
Post Options Post Options   Thanks (0) Thanks(0)   Quote sparky Quote  Post ReplyReply Direct Link To This Post Posted: 08 May 2023 at 8:15am
Thanks
