AC engine assembly problem
WF owner View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote WF owner Quote  Post ReplyReply Direct Link To This Post Topic: AC engine assembly problem
    Posted: 01 May 2023 at 2:22pm
I am assembling an engine with a 201 (WF) block with a 4.5" (WD45) crankshaft, WD45 connecting rods and (D-17) 7.5/1 pistons. The mains are -.030 and the rods are -.020. I have checked and all (new) main and rod bearings are the correct size.
I shimmed the mains and have everything in spec and it turns nice; easy and smooth.
Since I am using WD45 rods, they don't need shimming, but I have checked the clearances and all are correct. I have castellated nuts, so the book says rod bearings should be torqued to 70 ft. lbs. I tightened the rod bearings at 20 ft. lbs. and it turns nice. Increased to 40 ft. lbs. and still turned nice. When I increase to 50 ft. lbs., it starts to turn harder than I think it should and at 60 ft. lbs., I can barely turn it.
I find it odd that lock nuts (which have more resistance to turn) torque spec is only 40 ft. lbs. and castellated nuts torque to 70 ft. lbs.
I have checked the bearing caps and all are oriented correctly.
Suggestions?
Post Options Post Options   Thanks (0) Thanks(0)   Quote steve(ill) Quote  Post ReplyReply Direct Link To This Post Posted: 01 May 2023 at 5:31pm
thats what the book says... but i would have thought just the opposite.. the LOCK NUTS have some torque resistance to get them to turn... you add that to the REQUIRED TORQUE and get the total.... Normally a LOCK NUT has a higher torque value than a standard nut..
What is the diameter of the bolts ?  3/8 or 7/16  ?
Post Options Post Options   Thanks (0) Thanks(0)   Quote WF owner Quote  Post ReplyReply Direct Link To This Post Posted: 01 May 2023 at 5:37pm
I thought the same thing. The castellated nuts have no resistance when torquing them, plus they are wired to keep them from loosening.
The rod nuts take a 5/8" wrench, so I assume the bolts are 7/16".
Post Options Post Options   Thanks (0) Thanks(0)   Quote steve(ill) Quote  Post ReplyReply Direct Link To This Post Posted: 01 May 2023 at 5:48pm
yea, something seems wrong.. Maybe Dr or someone with more background knowledge will jump in......... 70 is too high for a 7/16 bolt in my opinion..
note the torque on the smaller B-C motor ... not depending on nut style.
plummerscarin View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote plummerscarin Quote  Post ReplyReply Direct Link To This Post Posted: 01 May 2023 at 6:49pm
Just throwing this out there but is this a case of an offset rod or piston and when torqued to spec is when binding occurs?
Post Options Post Options   Thanks (0) Thanks(0)   Quote WF owner Quote  Post ReplyReply Direct Link To This Post Posted: 01 May 2023 at 6:52pm
Post Options Post Options   Thanks (0) Thanks(0)   Quote WF owner Quote  Post ReplyReply Direct Link To This Post Posted: 01 May 2023 at 6:57pm
I was pretty careful to follow the instructions in the service manual when I was putting them together. Everything rotates fine when torqued to 40 ft. lbs., starts to bind at 50 ft. lbs. and turns very hard at 60.
Post Options Post Options   Thanks (0) Thanks(0)   Quote WF owner Quote  Post ReplyReply Direct Link To This Post Posted: 01 May 2023 at 7:49pm
I have been using an AC Service Manual for my specs. I just checked an IT manual and it says exactly the same.
Acdiesel View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Acdiesel Quote  Post ReplyReply Direct Link To This Post Posted: 01 May 2023 at 8:18pm
I WOULD TRY  THE SELF-LOCKING NUTS AND TORQUE THEM TO THE 40 LBS. AND SEE HOW SHE TURNS OVER.
D19 Diesel,D17 Diesel SER.3
2-D14, 2-D15 SER.II WF/NF
D15 SER.2 DIESEL
D12 SER.I, D10 Ser.II
2-720'S D21 Ser. II
Gmc,caterpillar
Rod in MN View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Rod in MN Quote  Post ReplyReply Direct Link To This Post Posted: 01 May 2023 at 8:37pm
What I would try is to tighten one rod and check for the rod to have side play . Same with the wrist pin that it is not pushing on one side of the piston. Do that to each rod one at a time. Back the of the one you did first.
And when you torquing the nuts if torque is 70ft lbs. first torque the nut to 40 . Then on your final torque go to 70 ft lbs but do that final one with out stoping from 40 to 70 . If you don’t your final torque will be off.
Good luck
