Balpak bearings
mruhlig77 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote mruhlig77 Quote  Post ReplyReply Direct Link To This Post Topic: Balpak bearings
    Posted: 29 Apr 2023 at 3:34pm
are there one or two bearings in a balpak....need to see a picture of one cut apart...Mark
ac hunter View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote ac hunter Quote  Post ReplyReply Direct Link To This Post Posted: 29 Apr 2023 at 4:39pm
look on the farm equipment-knowledge base on this forum; there is an excellent post on those bearings.
Post Options Post Options   Thanks (0) Thanks(0)   Quote mruhlig77 Quote  Post ReplyReply Direct Link To This Post Posted: 30 Apr 2023 at 12:55pm
Thanks Mr. Hunter...but it does not have that cross section info....Mark
Allis dave View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Allis dave Quote  Post ReplyReply Direct Link To This Post Posted: 01 May 2023 at 6:48am
Hello Mark,
I'm the one that wrote that knowledgebase bearing post. Further down in the article it was a comment including one of the original pics of a failed bearing that I took apart. All parts are in that pic.
The bearing assembly includes a single bearing, 2 bushings(spacers), and two seals. Pressed through the center of the bearing, bushings, and seal, is a tube wiht a round or hex center depending if you have a round or hex shaft.
All of this is pressed inside the large exteral tube that you see when you look at the disk.
Post Options Post Options   Thanks (0) Thanks(0)   Quote mruhlig77 Quote  Post ReplyReply Direct Link To This Post Posted: 01 May 2023 at 7:07am
Thanks...but you are saying the just one bearing is in the exact middle...there must be a lot of air space  between the bearing and the outside seals....hence why needed a crosssection picture...there isn't one in my disk book either....Thanks for trying to help...Mark
Alvin M View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Alvin M Quote  Post ReplyReply Direct Link To This Post Posted: 01 May 2023 at 11:23am
I use two of BCA 88107A in each one no other parts are needed they are sealed
Post Options Post Options   Thanks (0) Thanks(0)   Quote Mikez Quote  Post ReplyReply Direct Link To This Post Posted: 01 May 2023 at 11:30am
The way I read it mark isn’t asking the fix. He’s asking what’s in the original bearing.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Alvin M Quote  Post ReplyReply Direct Link To This Post Posted: 01 May 2023 at 11:34am
Press it apart then you will see ball bearing
Post Options Post Options   Thanks (0) Thanks(0)   Quote Allis dave Quote  Post ReplyReply Direct Link To This Post Posted: 01 May 2023 at 11:35am
You're correct Mark. There is just one bearing in the middle. Some of that "air" space is filled by those bushings. The little that was left I don't know if it was all filled wiht the seal or what. It's been awile, but in the picture the seal looks pretty thick.
I filled up my air space wiht the felt seal and rubbed greas into it.
This page was generated in 0.166 seconds.
