Wtb 153 buda parts
im4racin View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote im4racin Quote  Post ReplyReply Direct Link To This Post Topic: Wtb 153 buda parts
    Posted: 29 Apr 2023 at 10:24am
Need a cam and oil pump for a g153 buda.
ac45dave View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote ac45dave Quote  Post ReplyReply Direct Link To This Post Posted: 30 Apr 2023 at 1:42pm
PM Sent. My buddy's son found this guy.He has a lot of Buda stuff.He's an older fella.Think the family had a dealership of some sort back in the day.Let us know how you come out on your quest.
Edited by ac45dave - 30 Apr 2023 at 1:51pm
JC-WI View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote JC-WI Quote  Post ReplyReply Direct Link To This Post Posted: 30 Apr 2023 at 11:34pm
Thats a fellow to ask about those old BUDA engines and find out what he knows!
Post Options Post Options   Thanks (0) Thanks(0)   Quote im4racin Quote  Post ReplyReply Direct Link To This Post Posted: 01 May 2023 at 7:01am
2 things
Is job87 on the scam list? He said to email someone with parts.
I talked with Phil he has b series parts but no g series parts at this time. Cam is different but all oil pumps are the same from b153 through g262 das or diesel so oil pump isn't an issue. I have a couple parts 6 cyl engines. He also said d175 cam from a d15d would work just not the same grind but would run.
Edited by im4racin - 01 May 2023 at 7:05am
Post Options Post Options   Thanks (0) Thanks(0)   Quote Mikez Quote  Post ReplyReply Direct Link To This Post Posted: 01 May 2023 at 8:27am
According to another post that is a scammer
Larry in NC View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Larry in NC Quote  Post ReplyReply Direct Link To This Post Posted: 01 May 2023 at 1:25pm
The 153g was used in Cockshutt 30 tractors.  I have some Cockshutt tractors and Phil Heisey is the parts guy for Cockshutt.  He may be able to help you.  His number is 215-256-8651.  Located in PA
Post Options Post Options   Thanks (0) Thanks(0)   Quote im4racin Quote  Post ReplyReply Direct Link To This Post Posted: 01 May 2023 at 6:29pm
I HAVE TALKED TO PHIL.  He doesn’t have any g series parts at this time.
Post Options Post Options   Thanks (0) Thanks(0)   Quote im4racin Quote  Post ReplyReply Direct Link To This Post Posted: 04 May 2023 at 1:30pm
Found a cam and gasket set.
Grindstaff engines out of Missouri has some parts. Very knowledgeable and great to work with.
Gary Burnett View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Gary Burnett Quote  Post ReplyReply Direct Link To This Post Posted: 07 May 2023 at 4:35pm
I have a 175 motor
