Can't get my plow to raise
orangeman Ia View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote orangeman Ia Quote  Post ReplyReply Direct Link To This Post Topic: Can't get my plow to raise
    Posted: 15 Oct 2010 at 7:37pm
I have a  Wd- 45 with a snap coupler plow, and I can only get it to raise two to three inches off the ground. Could any of you guys help me out  to get more lift on it? Thank you.
Stan R View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Stan R Quote  Post ReplyReply Direct Link To This Post Posted: 15 Oct 2010 at 7:41pm
Low oil??
Post Options Post Options   Thanks (0) Thanks(0)   Quote orangeman Ia Quote  Post ReplyReply Direct Link To This Post Posted: 15 Oct 2010 at 7:52pm
The oil is at the right level
Post Options Post Options   Thanks (0) Thanks(0)   Quote AMB(wcIL) Quote  Post ReplyReply Direct Link To This Post Posted: 15 Oct 2010 at 7:59pm
Maybe the lift straps pivots are over center/upside down, causing the lifting distance to be longer.  That will cause the plow not to lift very high.  Andy
Post Options Post Options   Thanks (0) Thanks(0)   Quote CTuckerNWIL Quote  Post ReplyReply Direct Link To This Post Posted: 15 Oct 2010 at 8:08pm
Look at the picture and see if your plow is hooked up like this one. The pivot for the plow lift hangs down below the cross bar.
Ed in TX View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Ed in TX Quote  Post ReplyReply Direct Link To This Post Posted: 15 Oct 2010 at 9:12pm
When my plow won't raise I take one of those little blue pills.
Larry in OK View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Larry in OK Quote  Post ReplyReply Direct Link To This Post Posted: 15 Oct 2010 at 9:55pm
Cialis for tractors?
Some people are like Slinkies. Not really good for much of anything but they still bring a smile to your face when you push them down a flight of stairs.
