Front end for an XT
darrel in ND View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote darrel in ND Quote  Post ReplyReply Direct Link To This Post Topic: Front end for an XT
    Posted: 28 Apr 2023 at 10:19am
I am in the need of a front axle/wishbone assembly for my one ninety XT. If anyone has a good one for sale, let me know through here. Thanks, Darrel
brouillettefarms View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote brouillettefarms Quote  Post ReplyReply Direct Link To This Post Posted: 28 Apr 2023 at 12:11pm
I have a very nice front end for one, 812-881-7654
Post Options Post Options   Thanks (0) Thanks(0)   Quote darrel in ND Quote  Post ReplyReply Direct Link To This Post Posted: 29 Apr 2023 at 8:42am
Where are you located, and how much $$$$ for it?
Thanks, Darrel
Post Options Post Options   Thanks (0) Thanks(0)   Quote brouillettefarms Quote  Post ReplyReply Direct Link To This Post Posted: 29 Apr 2023 at 9:23am
Vincennes Indiana, $300
JC-WI View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote JC-WI Quote  Post ReplyReply Direct Link To This Post Posted: 30 Apr 2023 at 11:39pm
Darrel what you do to your old frontend?
 Corners breaking out? If so, grab the welder and go to work welding it up and put a corner brace in there for extra support. They seem to break in the rear left corner and it is due to the stresses of the steering cylinder.
Post Options Post Options   Thanks (0) Thanks(0)   Quote darrel in ND Quote  Post ReplyReply Direct Link To This Post Posted: 02 May 2023 at 5:15pm
JC, it got relentless hours of loader use this winter moving snow and feeding cattle, and I guess that the front end finally said that it had enough! That corner piece did break, but someone prior to me welded it up before. Then one of the main channel irons broke in half in the middle, and one of the outer braces broke off of the axle. Son was running it at the time. I have thought about rebuilding it, using reinforcement, but I might not like how it looks. We finally got our payloader going again, so it shouldn't get used so hard any more. I have several people have messaged me with them for sale, at reasonable prices, but distance is kind of a killer on them. Pondering on it for now. Even had a scammer offer one to me.
Darrel
Leon B MO View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Leon B MO Quote  Post ReplyReply Direct Link To This Post Posted: 05 May 2023 at 8:16am
I have used Fastenal several times for shipping larger items. If you have one relatively close by it may be something you could check into. I shipped 2 chaffers out of an L3 combine through them in a cleaned out chemical tote pallet/cage. It actually worked quite well.
Leon B Mo
Lon(MN) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Lon(MN) Quote  Post ReplyReply Direct Link To This Post Posted: 06 May 2023 at 7:23am
I have a wishbone. One corner has been welded.
http://lonsallischalmers.com
