WD pressure plate adjustment and torque
Don(MI) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Don(MI) Quote  Post ReplyReply Direct Link To This Post Topic: WD pressure plate adjustment and torque
    Posted: 15 Oct 2010 at 7:23pm
Hey all, I am finally putting the clutch together on the WD. Should the outer 6 bolts that hold the pressure plate on be torqued for tightness? Or is this just a guess on how tight they should be? Also, When adjusting the pressure plate forks through the bell housing, is there a correct distance between the forks and thrust bearing? Just wondering, this is really my first clutch job. Thanks! Don
Gary in da UP View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Gary in da UP Quote  Post ReplyReply Direct Link To This Post Posted: 15 Oct 2010 at 7:27pm
 Yes , get grade 8 bolts and torque to 22~24 ft/lbs.  I don't know off hand but a 1/4" on fork to throw -out bearing I'd guess.
Post Options Post Options   Thanks (0) Thanks(0)   Quote CTuckerNWIL Quote  Post ReplyReply Direct Link To This Post Posted: 15 Oct 2010 at 7:42pm
174, ADJUSTMENT. Clutch pedal
should have 1/2 to one inch of free
travel when measured between pedal
and top of tractor frame rail. This
amount of free pedal travel produces
the desired clearance of 1/4 inch between
release bearing face and face
of release levers. Adjustment is made
by turning the threaded pivot (12—
Fig. AC77).
mlpankey View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote mlpankey Quote  Post ReplyReply Direct Link To This Post Posted: 15 Oct 2010 at 7:50pm
use new grade 8 bolts and loctite them .
Post Options Post Options   Thanks (0) Thanks(0)   Quote Don(MI) Quote  Post ReplyReply Direct Link To This Post Posted: 16 Oct 2010 at 10:10am
thanks!
