HD6G Fuel in crankcase
Paul-HD6G Start-up View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Paul-HD6G Start-up Quote  Post ReplyReply Direct Link To This Post Topic: HD6G Fuel in crankcase
    Posted: 26 Apr 2023 at 7:02am
I have an HD6G that sat for 15 years or so.  I started right up after a battery change and new fuel.  I seems to be getting fuel into the crankcase.  I could use help with the cause and how to repair.  Possibly the fuel transfer pump?Thanks in advance.
CAL(KS) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote CAL(KS) Quote  Post ReplyReply Direct Link To This Post Posted: 26 Apr 2023 at 7:24am
99%  fuel transfer pump seal on side of injection pump.  easy fix
Edited by CAL(KS) - 26 Apr 2023 at 7:46am
Post Options Post Options   Thanks (0) Thanks(0)   Quote Paul-HD6G Start-up Quote  Post ReplyReply Direct Link To This Post Posted: 26 Apr 2023 at 7:27am
So do you simply pull the transfer pump, replace seal and reinstall?
Post Options Post Options   Thanks (0) Thanks(0)   Quote CAL(KS) Quote  Post ReplyReply Direct Link To This Post Posted: 26 Apr 2023 at 7:46am
yes, but been a few years since done one
Post Options Post Options   Thanks (0) Thanks(0)   Quote Paul-HD6G Start-up Quote  Post ReplyReply Direct Link To This Post Posted: 26 Apr 2023 at 10:58am
Thanks for the help.  almost sounds too easy to be true
HD6 Merv View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote HD6 Merv Quote  Post ReplyReply Direct Link To This Post Posted: 26 Apr 2023 at 2:52pm
yes lip type seal in gear type transfer pump.
 SKF 4231
tits tyres and tracks
they all cost you money
This page was generated in 0.234 seconds.
