Hydraulic seals
acd17toy View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote acd17toy Quote  Post ReplyReply Direct Link To This Post Topic: Hydraulic seals
    Posted: 25 Apr 2023 at 6:28pm
  Are the seals for the lift arms cylinders for the WD/wd45  the same as the ones for the AC loader cylinders?
Jim.ME View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Jim.ME Quote  Post ReplyReply Direct Link To This Post Posted: 26 Apr 2023 at 5:22pm
I will say no, I am guessing the loader cylinders are different sized rods and bores, as well as being different designs.
You are best to compare part numbers using the parts books.  If they work, here are links to the parts books for you.  First link should be the WD/WD45 parts book.  The second is the AGCO parts book for the AC Farm loaders, you need to pick the model loader you are thinking of.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Mikez Quote  Post ReplyReply Direct Link To This Post Posted: 27 Apr 2023 at 8:11am
222677 is part number. Should still be available through agco
DSeries4 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote DSeries4 Quote  Post ReplyReply Direct Link To This Post Posted: 27 Apr 2023 at 4:27pm
local hydraulic shop should have them
