CA head Gasket
Mikey Joe View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Mikey Joe Quote  Post ReplyReply Direct Link To This Post Topic: CA head Gasket
    Posted: 25 Apr 2023 at 6:31am
I have overhauled the engine on my CA and wondering about putting the head gasket on "dry" or using some type of sealant. The CA service manual says to use a non-hardening gasket cement. What about using Permatex Copper Gasket Spray on the new gasket?
Thanks in advance for suggestions
Mike
ac45dave View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote ac45dave Quote  Post ReplyReply Direct Link To This Post Posted: 25 Apr 2023 at 8:59am
Use a skim coat on both sides of the gasket around the outside perimeter, from the edge to 1/4" in from the edge.Also around the water holes and push rod holes both sides of the gasket.                                                    Hylomar Non-Setting, Non-Hardening Gasket Sealant, 100 g, Blue, Temp Range  -58 to 572 Degrees F HUB003 | Zoro
Edited by ac45dave - 25 Apr 2023 at 9:01am
Dakota Dave View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Dakota Dave Quote  Post ReplyReply Direct Link To This Post Posted: 25 Apr 2023 at 8:10pm
I use to use the copper spray the last couple blue felpro ones ive install dry the instructions wth them state warning indtall dry and retorque.Ive never had a problem when following the instructions
SEIA Farmer View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote SEIA Farmer Quote  Post ReplyReply Direct Link To This Post Posted: 25 Apr 2023 at 9:43pm
Check out my WC Dilema above!  I would highly recommend the anerobic gasket sealer!  It has excellent sealing properties and stays flexible.  I used a Permatex Anerobic Gasket Sealer product, Locktite has one also, as well as the Hylomar product shown.  I wouldn't install it dry...it's no fun doing it twice.
This page was generated in 0.091 seconds.
