Jacobsen mower overheating? |
Tracy Martin TN
Joined: 11 Sep 2009 Location: Gallatin,TN Points: 10936 |
Topic: Jacobsen mower overheating?Posted: 24 Apr 2023 at 9:50pm |
My Jacobsen mower overheated Friday. It has a inline 4 cylinder Ford engine, VSG 41111 -6007-b in it. Over the last year it would occasionally get to 220 if hot day and hard mowing.Got up to 240 degrees. I cooled it down washed out radiator and it started climbing again. Let it cool down, took out thermostat and tried it today, still overheats. Fan belt tight, full of coolant , no bubbles in top of radiator with cap off. What is most likely cause, water pump? I think radiator is okay. I am going to flush system very soon. Thanks Tracy
D19allisowner
Posted: 24 Apr 2023 at 11:00pm |
I would start by giving the cooling system a good flush first. Mabe possibly a head gasket going out but I'm no ford expert.
If you choose not to decide you still have made a choice.
Tracy Martin TN
Posted: 24 Apr 2023 at 11:10pm |
Radiator was boiled out when I put it on a couple years ago. I didn't see any bubbles in upper tank with it running, hoping it wasn't a head gasket. I will flush it out good and go from there. I was thinking maybe the water pump was going bad. This engine is used in Tennant floor sweepers and such. Thanks, Tracy
DiyDave
Joined: 11 Sep 2009 Location: Gambrills, MD Points: 55283 |
Posted: 25 Apr 2023 at 4:52am |
flush it out, then take an IR thermometer and start checking temps here and there...
jaybmiller
Joined: 12 Sep 2009 Location: Greensville,Ont Points: 25258 |
Posted: 25 Apr 2023 at 6:11am |
from the info, newer rad,flushed,tight belt, full of coolant, no stat.. Only way I can think is ...NO flow = overheating.....so I'd say water pump.
truckerfarmer
Joined: 26 Jan 2013 Location: Watertown, SD Points: 3312 |
Posted: 25 Apr 2023 at 6:45am |
Couple of questions. First, you washed out the radiator. Did you just use the garden hose, or did you use some pressure? Just running water through it without pressure doesn't get the stuff that's caked on.
Second, have you tried a new thermostat? No thermostat will cause overheating also. Without a thermostat, water flows through the radiator to fast and doesn't get a chance to cool down. Fought a similar problem on my TL12 loader. New radiator, new head gasket. Still overheating. Finally took thermostat housing off. No thermostat!. Put in a thermostat, problem solved. |
'53 WD, '53 WD45, WD snap coupler field cultivator, #53 plow,'53 HD5B dozer Duct tape.... Can't fix stupidity. But will muffle the sound of it! |
SteveM C/IL
Joined: 12 Sep 2009 Location: Shelbyville IL Points: 8982 |
Posted: 25 Apr 2023 at 7:23am |
Use IR gun first to confirm it's hot.
Tracy Martin TN
Posted: 25 Apr 2023 at 8:59pm |
Took the pump off today. It seems OK, but it sure is mickey mouse looking.. I am going to flush it good with a radiator flush. It has lots of rust crude particals in it. Probably going to replace pump while I got it apart. It is not at a handy place to work on either. I will keep you posted.Hoping it aint a head gasket. Tracy
DaveKamp
Posted: 25 Apr 2023 at 9:35pm |
VG-411 is the 'Valencia', that's a 1.1L four. Lucky for you, it's not the 172/192 four... they had terrible problems with steam pocketing. Do all that you're doing, then verify that your mechanical advance and vacuum advance are both functioning properly, and your base is 6deg BTDC. mechanical is 3-9, and vac is 12-30. If one or the other, or both aren't functioning right, it will NOT be happy. Here's the specs sheet: and the service manual can be downloaded here: Foley Engines is where I'd look for Ford Industrial engine parts- they know those engines well.
Edited by DaveKamp - 25 Apr 2023 at 9:36pm |
Tracy Martin TN
Posted: 26 Apr 2023 at 9:11pm |
I flushed out the block and radiator with a garden hose this afternoon. Will fill it with water and Blue Devil radiator flush, get it up to temp and run it a hour or two, cool it down and rinse the flush out. It had a lot of crap in block and radiator. Washed out radiator fins behind oil cooler too. It has dirt and grass in it too. Another day or two before I will be done with what little time I get on it. Thanks, Tracy
Tracy Martin TN
Thanks(1)
Posted: 29 Apr 2023 at 8:20pm |
I put Blue Devil in her today and ran about two hours. Pretty sure my sending unit or temp gauge is bad. Just after a couple on minutes the gauge pegged at 300. Using my infared thermometer it all checked good. Top of tank was hotter than bottom. Flushed the Blue Devil out from both directions. What is easiest way to check temp gage and sending unit? Thanks, Tracy
DiyDave
Posted: 30 Apr 2023 at 4:40am |
Take the SU out, put it in a can of water, boil with a torch, check temps with the IR thermometer...
DonBC
Joined: 12 Sep 2009 Location: Courtenay, BC, Points: 947 |
Posted: 30 Apr 2023 at 1:08pm |
Have you checked the timing
Tracy Martin TN
Posted: 30 Apr 2023 at 6:43pm |
It is the sending unit. I turned key on and fiddled with sending unit wire. It would peg out at 300 some places, wiggle it some, drop back to zero. Tried tightening it up and threaded stud is loose. Easy to get to though. Thanks for all the advice. Tracy
Tracy Martin TN
Posted: 04 May 2023 at 7:11pm |
I put in new sending unit and filled her up with coolant. Ran right at 170 while mowing. I am happy again! Thanks, Tracy
Tracy Martin TN
Posted: 15 May 2023 at 8:30pm |
Spoke too soon, got hot on me yesterday. I think the thermostat stuck. Cooled off, started and ran around 205. Going to flush it again. New thermostat, and have radiator rodded. Going to check coolant for combustion gases also, could have a blown head gasket. Tracy
Tracy Martin TN
Posted: 27 May 2023 at 8:10pm |
Checked coolant tank for combustion gases, none found. Did flush system again,then flushed out flush really good. Bought a new thermostat and drill small hole in flange. Checked it in pan of water. It tested OK installed it.. Had the radiator boiled out, radiator guy tested flow and said it was as good as a new one, no need to rod it. Installed it. Filled up system and ran mower for 15 minutes, never above 175. Mowed with it for 3 hours and never above 175. I think I got it fixed, sure feels better seeing it run cooler. Tracy
jaybmiller
Posted: 27 May 2023 at 8:53pm |
whew ! that's good news... i was kinda running out of ideas ..... Jay
steve(ill)
Joined: 11 Sep 2009 Location: illinois Points: 90832 |
Posted: 27 May 2023 at 9:24pm |
Tracy, my son has a Side x Side that has a 180 degree thermostat and a sensor that turns the radiator fan on when the cylinder head gets to 205 degrees.... then the IDIOT light comes on at 210 !! ...... We hot wired the fan to run constant... Now the temp is 170 degrees all the time .......... Keep fan operation in mind !
