A way to add weight to front end wd 45
dr p View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote dr p Quote  Post ReplyReply Direct Link To This Post Topic: A way to add weight to front end wd 45
    Posted: 22 Apr 2023 at 7:37am
Put the 54 plow on the wd45 narrow front end this morning and gave it a test run. Plenty of traction when pulling but the front is too light when i lift the plow. Slab weights eould be great but they are hard to find . What are thoughts on filling front tires with beet juice?
Gary View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Gary Quote  Post ReplyReply Direct Link To This Post Posted: 22 Apr 2023 at 7:49am
There are Wheel Weights meant for 15" and 16" wheels
The Allis Casting No. is AM 3684
G
OR you could go to the 'Pulling Forum' section and search for some pictures of Forum Members pulling with a WD or WD-45 and see how they add front weight.
Edited by Gary - 22 Apr 2023 at 7:54am
IBWD MIke View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote IBWD MIke Quote  Post ReplyReply Direct Link To This Post Posted: 22 Apr 2023 at 8:40am
These are weights for a later 100 series, work pretty good for plowing.
Post Options Post Options   Thanks (0) Thanks(0)   Quote SteveM C/IL Quote  Post ReplyReply Direct Link To This Post Posted: 22 Apr 2023 at 10:23am
Mike's version makes most sense. I have a plate across front with 14in of air tank welded to it sticking fwd. Mounts F&H rear wheel weights. Just what I had around.
Joe(TX) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Joe(TX) Quote  Post ReplyReply Direct Link To This Post Posted: 22 Apr 2023 at 11:36am
My dad used a square bar supported by the front cultivator mount.
captaindana View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote captaindana Quote  Post ReplyReply Direct Link To This Post Posted: 22 Apr 2023 at 11:39am
Mike that’s a real nice set up!
Blue Skies and Tail Winds
                          Dana
Post Options Post Options   Thanks (0) Thanks(0)   Quote captaindana Quote  Post ReplyReply Direct Link To This Post Posted: 22 Apr 2023 at 11:42am
Dr p personally, I would put the calcium chloride right to the front tires and just replace the valve stems every couple years. And maybe front wheel weights also.
                          Dana
Dusty MI View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Dusty MI Quote  Post ReplyReply Direct Link To This Post Posted: 22 Apr 2023 at 12:26pm
 We had a '53 WD, it had tubes  and calcium chloride in all 4 tires.
ACinSC View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote ACinSC Quote  Post ReplyReply Direct Link To This Post Posted: 22 Apr 2023 at 3:08pm
Water in my D 15 front tires added about 70 lbs per tire . Still haven't been out to the farm to see how much difference it made . Good luck
dr p View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote dr p Quote  Post ReplyReply Direct Link To This Post Posted: 22 Apr 2023 at 6:36pm
Tried an anvil today with a bunch of rackets straps. Plan b tomorrow
Post Options Post Options   Thanks (0) Thanks(0)   Quote DrAllis Quote  Post ReplyReply Direct Link To This Post Posted: 22 Apr 2023 at 8:01pm
I don't particularly care for any fluid in front tires. They steer harder and it's permanent. Weights that can be added and removed is best.
jvin248 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote jvin248 Quote  Post ReplyReply Direct Link To This Post Posted: 22 Apr 2023 at 8:29pm
My WF '52 WD came with a four foot piece of railroad track for a bumper/weight.
I have seen a few metal boxes bolted on tractor frames and filled with rocks or sand.
Dakota Dave View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Dakota Dave Quote  Post ReplyReply Direct Link To This Post Posted: 23 Apr 2023 at 7:27am
I’ve strapped a 30 gallon barrel to the front filled with water when done I siphoned the water out and took it off. when I returned the 3 pt pallet forks to the farm I no longer needed the wieght. It was very cheep and easy an empty plastic barrel is light and easy to install with a couple ratchet straps.
Post Options Post Options   Thanks (0) Thanks(0)   Quote IBWD MIke Quote  Post ReplyReply Direct Link To This Post Posted: 23 Apr 2023 at 8:48am
Thanks Dana. One of the more creative re-purposing of weights I've seen was pie-weights from an N Ford mounted on the original round bracket on the front of a 656. I have a box-full of them on the three point of my 720. Helps a bunch pushing snow!
