d 14 need help
mike kennedyididitok View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote mike kennedyididitok Quote  Post ReplyReply Direct Link To This Post Topic: d 14 need help
    Posted: 17 Apr 2023 at 5:53pm
removed carb for rebuild . rod to throttle has small hole, about midway, for spring. what does spring attach to and what is its function. thanks in advance
Post Options Post Options   Thanks (0) Thanks(0)   Quote steve(ill) Quote  Post ReplyReply Direct Link To This Post Posted: 17 Apr 2023 at 6:29pm
some tractors will SURGE... rpm moving up and down randomly when they set there idling... The spring slows down the surge or puts a Damper on it... On the smaller tractor, the spring hooks around an exhaust manifold bolt.
If the carb is set PERFECTLY calibrated, it may not need the spring. I have a few tractors that have no spring.. not needed.
Post Options Post Options   Thanks (0) Thanks(0)   Quote steve(ill) Quote  Post ReplyReply Direct Link To This Post Posted: 17 Apr 2023 at 6:32pm
some additional opinions... on the smaller "B", surge spring.
Post Options Post Options   Thanks (0) Thanks(0)   Quote jaybmiller Quote  Post ReplyReply Direct Link To This Post Posted: 17 Apr 2023 at 6:40pm
yeah, 'antisurge' spring.... loops around one of the manifold studs, I think...
'someone's ' playing with his machine, otherwise I'd go out and check, but yeesh, had to put the furnace on again.....brrrrrr ........grrrrrr
Post Options Post Options   Thanks (0) Thanks(0)   Quote DMiller Quote  Post ReplyReply Direct Link To This Post Posted: 17 Apr 2023 at 7:08pm
Sounds a Vacuum leak to me.
Rogers View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Rogers Quote  Post ReplyReply Direct Link To This Post Posted: 20 Apr 2023 at 10:51pm
The spring hooks from the rod to an intake manifold bolt. The spring keeps the engine from surging.
Think for yourself and be your own expert. Be willing to change your mind; however, willingness to change your mind doesn’t mean that you will. Blindly following any path is the pinnacle of insanity.
