7030 injector replacement
DIESEL View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote DIESEL Quote  Post ReplyReply Direct Link To This Post Topic: 7030 injector replacement
    Posted: 16 Apr 2023 at 10:07am
Changing the injectors on my 7030,I've got the old ones out and see the new ones have 2 felt washers. The old ones had a rubber sealing washer that was hard as a rock, I'm just curious is there a reason a person wouldn't use some kind of sealant around the injector to keep moisture out instead of the felt washers. Thanks
Post Options Post Options   Thanks (0) Thanks(0)   Quote DrAllis Quote  Post ReplyReply Direct Link To This Post Posted: 16 Apr 2023 at 10:32am
Two felt washers was what they used. That thick rubber one was used on later engines altho they do get used where two felt ones go as well. Antiseize the injector bodies to help prevent rusting in the bores.
Post Options Post Options   Thanks (0) Thanks(0)   Quote MACK Quote  Post ReplyReply Direct Link To This Post Posted: 16 Apr 2023 at 8:25pm
I like the thicker rubber best. If copper at bottom don't seal, the thick ones will sound like a fart.                       MACK
Post Options Post Options   Thanks (0) Thanks(0)   Quote DrAllis Quote  Post ReplyReply Direct Link To This Post Posted: 17 Apr 2023 at 11:21am
Big smileBig smileBig smile
This page was generated in 0.112 seconds.
