715 backhoe parts
Chris Dame View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Chris Dame Quote  Post ReplyReply Direct Link To This Post Topic: 715 backhoe parts
    Posted: 11 Apr 2023 at 5:38pm
Looking for valve assembly on the forward reverser for 715 allis chalmers backhoe. Part # 1002958 in the parts book. Need help please.
KRAKMT View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote KRAKMT Quote  Post ReplyReply Direct Link To This Post Posted: 14 Apr 2023 at 12:10pm
I had mine rebuilt by a hydraulic shop. If you need a whole new unit- may be Minnpar?
Post Options Post Options   Thanks (0) Thanks(0)   Quote Chris Dame Quote  Post ReplyReply Direct Link To This Post Posted: 14 Apr 2023 at 12:26pm
Been trying to get ahold of them for 2 weeks website won't come up and no one answers the phone
Post Options Post Options   Thanks (0) Thanks(0)   Quote KRAKMT Quote  Post ReplyReply Direct Link To This Post Posted: 14 Apr 2023 at 12:48pm
You might email
rachel.obrien@minnpar.com
Post Options Post Options   Thanks (0) Thanks(0)   Quote DMiller Quote  Post ReplyReply Direct Link To This Post Posted: 14 Apr 2023 at 12:56pm
Just did my own search for a buddy, look up Trupar, they may have been either bought out or have signed off on liquidation.
Edited by DMiller - 14 Apr 2023 at 1:14pm
Post Options Post Options   Thanks (0) Thanks(0)   Quote Chris Dame Quote  Post ReplyReply Direct Link To This Post Posted: 14 Apr 2023 at 6:10pm
Thank you
Post Options Post Options   Thanks (0) Thanks(0)   Quote Chris Dame Quote  Post ReplyReply Direct Link To This Post Posted: 14 Apr 2023 at 6:15pm
Tried tripartite no luck.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Chris Dame Quote  Post ReplyReply Direct Link To This Post Posted: 14 Apr 2023 at 6:16pm
Sorry tripar
Post Options Post Options   Thanks (0) Thanks(0)   Quote DMiller Quote  Post ReplyReply Direct Link To This Post Posted: 14 Apr 2023 at 6:59pm
trUpar
Kcgrain View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Kcgrain Quote  Post ReplyReply Direct Link To This Post Posted: 08 Jul 2023 at 6:57am
The transmission shuttle is a borg-warner if I remember right, and its the same unit case used in the 580, so you can probably get a new one at your local Case industrial dealer
Post Options Post Options   Thanks (0) Thanks(0)   Quote Coke-in-MN Quote  Post ReplyReply Direct Link To This Post Posted: 09 Jul 2023 at 3:09pm
that fwd/rev unit is used on many marine uses and I got the rebuild kit from a marine outfit along with a rebuilt torque converter .
 Somewhere on this site I posted the name of the outfit that supplied everything i needed , problem is I don't have the record of the place handy .
 So the unit has a wide use besides the 715 TLB
Codger View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Codger Quote  Post ReplyReply Direct Link To This Post Posted: 09 Jul 2023 at 5:38pm
I've used both vendors in the past with good service. Joseph is better with the older stuff back into the 1960's.
That's All Folks!
Old Dan View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Old Dan Quote  Post ReplyReply Direct Link To This Post Posted: 28 Jul 2023 at 12:01pm
My 715 was built in 1974 and requires a ball joint for each of the 4 cylinders under the two control leveris to control the backhoe. One of the ball joints cam apart (from rust) and after much searching I found place which sold them but the minimum was 12 in a package.
That leaves me with 8 extra ball joints for anybody else needing them. The part number is 1006225. I live at Champaign, IL.
orangeman View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote orangeman Quote  Post ReplyReply Direct Link To This Post Posted: 31 Jul 2023 at 3:55pm
Old Dan - sent you a PM about the ball joints.  ~ Orangeman
Post Options Post Options   Thanks (0) Thanks(0)   Quote Old Dan Quote  Post ReplyReply Direct Link To This Post Posted: 31 Jul 2023 at 4:14pm
I paid $$6.85 each
I need no profit, only shipping cost to you.l
Post Options Post Options   Thanks (0) Thanks(0)   Quote Old Dan Quote  Post ReplyReply Direct Link To This Post Posted: 31 Jul 2023 at 7:40pm
Call me at (779) 529-2920 if you want
This page was generated in 0.305 seconds.
