D10 Brakes
Coolharts View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Coolharts Quote  Post ReplyReply Direct Link To This Post Topic: D10 Brakes
    Posted: 09 Apr 2023 at 2:05pm
I have the Left D10 axle housing off because of no brakes, there was nothing but grease in there. I think they will clean up ok and the shoes have plenty of material but is there supposed to be a seal for the axle? I don't see one.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Coolharts Quote  Post ReplyReply Direct Link To This Post Posted: 09 Apr 2023 at 5:53pm
Found what I need 70261958
Rick View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Rick Quote  Post ReplyReply Direct Link To This Post Posted: 09 Apr 2023 at 7:42pm
When you find out that degreasing the material doesn't work like a person thinks it should...contact me...I can reline your brakes for you for both sides for 100.00, plus shipping of 17.10, but I'll need your cores first...Rick
WF owner View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote WF owner Quote  Post ReplyReply Direct Link To This Post Posted: 10 Apr 2023 at 6:30am
... and when Rick gets done with them, they will be better than any aftermarket brakes you can buy anywhere.
Rick's work is very high quality and he uses only the best materials.
Rick View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Rick Quote  Post ReplyReply Direct Link To This Post Posted: 10 Apr 2023 at 8:47am
Thanks, Curt!  I appreciate the gesture...was trying to point out the fact that most degreaser sprays don't dry the material or get all of the oil/grease out...just superficial and will keep seeping through the material, just to have the same problem again and again. Been there and done that myself. The only thing I have ever seen that dried out the brakes real good, is to put them in a hot tank degreaser for a good while and then they MIGHT dry them out, if they're not too saturated in the oil. That stuff is trying to be outlawed though, because being so hazardous and harmful to breathe...Trychlorethylene...very nasty stuff!!!
Post Options Post Options   Thanks (0) Thanks(0)   Quote Coolharts Quote  Post ReplyReply Direct Link To This Post Posted: 10 Apr 2023 at 12:37pm
I am thinking about it but I am going to have to figure out how to support the tractor with no rear wheels on it.
DSeries4 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote DSeries4 Quote  Post ReplyReply Direct Link To This Post Posted: 10 Apr 2023 at 3:40pm
You have to do one side at a time.  If you remove both axles, you will drop the bull gear in the rear end, then your brake job suddenly became much bigger.
