WC crankshaft wick
Loren-ia View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Loren-ia Quote  Post ReplyReply Direct Link To This Post Topic: WC crankshaft wick
    Posted: 09 Apr 2023 at 9:40am
Pulled the engine out of the WC to do the pan gasket and rear main seal. Decided to replace the pilot bearing while I have it out. Crankshaft still has the wick in and the new pilot bearing is sealed. Think I read once to remove the wick and plug the hole in the crank. What do I plug the hole with, a cork or silicone?
IBWD MIke View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote IBWD MIke Quote  Post ReplyReply Direct Link To This Post Posted: 10 Apr 2023 at 7:19am
Seems like Don Bradley talked about this but I don't remember what he said to use.
Edit; It may be in the oil pan gasket thread in the knowledge base section.
Edited by IBWD MIke - 10 Apr 2023 at 7:21am
WF owner View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote WF owner Quote  Post ReplyReply Direct Link To This Post Posted: 11 Apr 2023 at 6:40am
IIRC, I think the suggestion was to tap threads into the crankshaft and install a pipe plug.
This page was generated in 0.036 seconds.
