Looking for a D2200 camshaft
Jim liddle View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Jim liddle Quote  Post ReplyReply Direct Link To This Post Topic: Looking for a D2200 camshaft
    Posted: 08 Apr 2023 at 9:50pm
I am looking for a D2200 camshaft for my HD4. The oil pump gear on mine has seen it’s better day.
troym View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote troym Quote  Post ReplyReply Direct Link To This Post Posted: 10 Apr 2023 at 7:05am
i would have one out of a 6080, not sure if its the same. is there a casting number on yours? 507 421 0213.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Jim liddle Quote  Post ReplyReply Direct Link To This Post Posted: 10 Apr 2023 at 8:45am
The number on mine is 4022456
Thanks
Post Options Post Options   Thanks (0) Thanks(0)   Quote troym Quote  Post ReplyReply Direct Link To This Post Posted: 11 Apr 2023 at 7:33am
i have one with that number but it does not have a oil pump drive gear this one is front driven off crank gear, don't know why the number is the same,
Post Options Post Options   Thanks (0) Thanks(0)   Quote DrAllis Quote  Post ReplyReply Direct Link To This Post Posted: 11 Apr 2023 at 8:16am
Because the p/n etched on the camshaft is the raw part. You can see the place where the oil pump drive gear would go. It just doesn't have the teeth cut into it as it isn't needed in newer engines.
This page was generated in 0.293 seconds.
