HD6G final drive lubrication
doctorcorey View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote doctorcorey Quote  Post ReplyReply Direct Link To This Post Topic: HD6G final drive lubrication
    Posted: 07 Apr 2023 at 7:34pm
I'm changing the fluid in the finals. I don't have a master service manual, and my small final drive manual makes no mention of type and quantity of fluid. If I recall on my 7G, it was filled with gear oil up to a bit below the fill plug. That's been 10 years ago, so I need the right oil spec and approx. quantity needed. I'm all but ready to start pushing dirt. I'm sumping everything on this tractor, the humidity and rapid temp changes around here lately is dumping condensation in every system. Cheers.
Semper Fi USMC    1958 HD6G, 1959 MF 203 loader, 1960 Case 420B Backhoe, MF 65 Tractor/Loader Diesel
Post Options Post Options   Thanks (0) Thanks(0)   Quote Coke-in-MN Quote  Post ReplyReply Direct Link To This Post Posted: 07 Apr 2023 at 7:52pm
Fill level is determined by filling the case from the 2 plugs in the extensions on back of case to proper level . Using a GL5 lube as there are timken bearings on all shafts and gears that run on bearings . I would use a lube higher than #90 wt - say 120 /140
 Capacity - unsure without finding my book but same on HD 5 or HD 6 as they use same rear case .
Post Options Post Options   Thanks (0) Thanks(0)   Quote doctorcorey Quote  Post ReplyReply Direct Link To This Post Posted: 07 Apr 2023 at 8:28pm
Thanks, Coke. I'll fill it 'till I can see it in the 'filler tube'. I'll be using thick stuff 'cause my left final weeps 'a little'. Smile  It looks like it can hold several gallons...
This page was generated in 0.570 seconds.
