Another Peterbilt Mystery
BuckSkin View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote BuckSkin Quote  Post ReplyReply Direct Link To This Post Topic: Another Peterbilt Mystery
    Posted: 07 Apr 2023 at 3:15am
Renfro Valley - Kentucky
Saturday_07-October-2006
I have determined the nearest Peterbilt, grey and black stripe, to be a 359.
Considering there is just walking room between the trucks, to my eye, the near truck stands head and ears taller than the other two Peterbilts.
The windshield is quite a bit taller.
The top of the hood looks to be farther from the ground.
Note how much more clearance is between the fenders and tires.
The other two Peterbilts do have the external breather tubes and scalloped hood like the 359; but, I believe them to be a different, shorter statured model.
The grilles even look shorter.
Any ideas ?
On another note:  That is Renfro Valley; notice how muddy the tires are on everything.
I have a longer distance shot of these same trucks and the foreground is full of big deep muddy ruts with water standing in them.
They have had events in that swamp for years and I have been to many of them; everything from rat killings to tent meetings; once you get past those girls with the nail aprons, you are on your own as to whether you ever hit hard ground again.
Many times, I have been there when they were log-chaining everyone in and out of the vast parking lot swamp with big tractors; and, many times I have came back to find my windshield and the sides of my truck spattered with mud from countless people spinning and slinging mud, trying to get in or out.
Once in a while, someone less experienced in such adverse conditions will fishtail into someone else's vehicle and it is always a horrendous fender-smashing crash.
You always get to see people on their knees, straining against the bumper of a spinning vehicle, while they are getting covered in mud.
In wet times, I have actually allowed discretion to be the better part of valor and vetoed leaving the house, foregoing an always looked forward to once-a-year hate-to-miss event on account of the fear of being out of sight and sound of my vehicle when someone slams into it.
Also, gum boots are strongly recommended; it is always funny to see these spike-heeled lipstick queens trying to navigate the muddy ground; you see a lot of muddy-legged gals carrying their stilletos by the straps.
Big blue crawdaddies everywhere and the stench of years of rotting food and vegetation hangs heavily in the air; when you first get there, it is plumb overwhelming nauseous; but, as the day wears on, you get accustomed to it and barely smell it at all --- but you can taste it --- even bust-your-teeth ice-cold drinks from the cooler will taste like it.
On the way back home, when you stop at a good sit-down restaurant where they bring you a menu and treat you like a human and don't take your money when you first walk in the door, you can't smell it on you, but be assured the other patrons can.
Thanks for reading.
TomC View Drop Down
Post Options Post Options   Thanks (1) Thanks(1)   Quote TomC Quote  Post ReplyReply Direct Link To This Post Posted: 07 Apr 2023 at 6:53am
I had a 1984,1988 and a1992 359 extended hoods, there was a noticable difference between the regular hoods and extended hoods, I think but not sure that first one is a 359 extended hood and the others are regular hoods
Post Options Post Options   Thanks (1) Thanks(1)   Quote steve(ill) Quote  Post ReplyReply Direct Link To This Post Posted: 07 Apr 2023 at 12:34pm
front glass seems to be the BIG difference in height.
Post Options Post Options   Thanks (0) Thanks(0)   Quote BuckSkin Quote  Post ReplyReply Direct Link To This Post Posted: 07 Apr 2023 at 1:08pm
That was my determination.
Although it would be better to have a side view, to my eye, it looks like the rear edge of the wheel-well on that first truck is ahead of the breather; whereas, on the other two, it appears it is well under the breather.
Post Options Post Options   Thanks (0) Thanks(0)   Quote BuckSkin Quote  Post ReplyReply Direct Link To This Post Posted: 07 Apr 2023 at 1:12pm
Yes; that's what jumped out at me and made me curious to know the reasons why.
I know it is an angling shot; but, those trucks were sitting close against each other; and, I don't think it is an optical illusion.
Post Options Post Options   Thanks (0) Thanks(0)   Quote DMiller Quote  Post ReplyReply Direct Link To This Post Posted: 08 Apr 2023 at 6:51am
Three points to note, second two trucks the suspension on front axle is either Lighter or been lowered, appears to be around two to three inches.  That based on bumper top edge positions, next up is Perception angle where the further away the more depth to angle as well the Eye Brow visor on the first is different from the window covering drop visors of the other two.  Short hoods and lower HP has a shorter grill top to bottom, as use a different radiator, Long Hood with Higher HP uses a taller radiator.  The closest unit is a 379(Rect Headlamps) the other two 359s, it also has 24.5 rubber the other 2 22.5s
For myself, I still prefer the late 50s early 60s Acar DC series lead in the line.  Probably a 190 or 220 cummins or even a 6L71 detroit
Edited by DMiller - 08 Apr 2023 at 6:55am
Michael V (NM) View Drop Down
Post Options Post Options   Thanks (1) Thanks(1)   Quote Michael V (NM) Quote  Post ReplyReply Direct Link To This Post Posted: 10 Apr 2023 at 6:19pm
All are 359's cept the far left one. all look to be standard hoods. Grey/black is a later model, square headlights were an option,the 2 on the right are "little window " from early 70's,, but yes all 359's, air cleaner inlet goes in hood side,, 379 air cleaner goes straight in the side cowel...
Walker View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Walker Quote  Post ReplyReply Direct Link To This Post Posted: 10 Apr 2023 at 7:53pm
You are aware the reason Jesus wasn't born there is because they couldn't find three wise men and a virgin?
This page was generated in 1.313 seconds.
