d17 clutch adjustment
panelbeater View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote panelbeater Quote  Post ReplyReply Direct Link To This Post Topic: d17 clutch adjustment
    Posted: 14 Oct 2010 at 5:36pm
the clutch seam to be slipping , is there an adjustment for this?  thanks
http://s2.photobucket.com/albums/y45/panelbeater/
DSeries4 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote DSeries4 Quote  Post ReplyReply Direct Link To This Post Posted: 14 Oct 2010 at 9:31pm
disconnect the rod from the pedal and unscrew it a bit.
Post Options Post Options   Thanks (0) Thanks(0)   Quote DrAllis Quote  Post ReplyReply Direct Link To This Post Posted: 15 Oct 2010 at 6:37am
Changing the length of the clutch pedal rod on a D17 has no effect. If this is anything other than a series 4, you can adjust the pressure plate fingers thru the small hole in the bellhousing to gain distance between the throwout brg and the fingers (freeplay). A series 4 you cannot and it will require a split to repair. First of all you have to determine if the foot clutch is slipping (probably) or the hand clutch (low or high side?) Adjusting the foot clutch pressure plate fingers will not fix the problem if the clutch is simply worn out.
gcalent View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote gcalent Quote  Post ReplyReply Direct Link To This Post Posted: 15 Oct 2010 at 10:02am
Although not used for primary clutch adjustment, the length of the pedal rod will effect the clearance from the throw out bearing to the fingers. If the pedal is against the floor board and the rod has been adjusted long, as the clutch wears the fingers can contact the release bearing and cause the clutch to slip. Changing the length of the rod will change the clearance buy moving the yoke that holds the release bearing, same effect as pushing on the pedal.
Pullin With AC
Post Options Post Options   Thanks (0) Thanks(0)   Quote panelbeater Quote  Post ReplyReply Direct Link To This Post Posted: 15 Oct 2010 at 11:13am
i i'm knew to ac, how do you know what series you have?
Post Options Post Options   Thanks (0) Thanks(0)   Quote gcalent Quote  Post ReplyReply Direct Link To This Post Posted: 15 Oct 2010 at 11:34am
Need a serial number, it`s on the left side of the bell housing just above the frame rail on a flat spot.
Pullin With AC
John (C-IL) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote John (C-IL) Quote  Post ReplyReply Direct Link To This Post Posted: 15 Oct 2010 at 11:43am
Serial number location on D series EXCEPT D19
Post Options Post Options   Thanks (0) Thanks(0)   Quote panelbeater Quote  Post ReplyReply Direct Link To This Post Posted: 17 Oct 2010 at 3:23pm
we're going to try and adjust the clutch fingers, would anybody know what the clearance is supposed to be. thanks
Post Options Post Options   Thanks (0) Thanks(0)   Quote DrAllis Quote  Post ReplyReply Direct Link To This Post Posted: 17 Oct 2010 at 3:30pm
 One-quarter inch would work nicely.
