WD generator overcharging & tire replacement help
Newwood View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Newwood Quote  Post ReplyReply Direct Link To This Post Topic: WD generator overcharging & tire replacement help
    Posted: 02 Apr 2023 at 10:23am
I've got a WD with Delco-Remy 3 brush generator (1101413 2c17)  with cutout relay, 6V positive ground with magneto that gets used once a year for about 8 hours to mow roads.  The good news is, it starts right up and works great.  But I noticed when I first got it about 3 years ago that it was charging at a high voltage (battery before starting is 6.4v, after starting climbs to 7.2, and after running a while is at 8.6--when measured at generator it is 9.1).  The ammeter was dead and the wiring was old, so after consulting here a couple years ago I replaced the wiring, put in a new ammeter, and refurbished the 3 way switch (although there are no lights on this machine, so that switch is simply controlling whether it goes through the resistor or straight to ground).  That hasn't fixed the high voltage problem, but I now can measure 7 amps (and 8.6v) running through the resistor and 16 amps (8.9v) going directly to ground.
It cranks well so I believe I have a good positive terminal to ground.  I know I could adjust the 3rd brush on the generator, but the manual is unclear as to whether that is affecting voltage or amp output (I suspect the later).  I have considered getting Steve in NJ to send me a voltage regulator--but would this solve my problem?
My second question is on advice of how to go about replacing tires on this tractor which is located in a relatively back-woods remote location.  These look pretty cracked to me (see photos) but I'm not sure just how evil-looking they get before failure--they're still working fine at the moment.  I don't have a trailer to haul the whole tractor into town.  Do you take the wheels off using the 8 central lugs, or the rims and tire off the wheel at the 4 clamps, or do you suggest calling some tractor-tire repair service (assuming one exists) to come out and do it on site?  I suspect these are deeply rusted into place, so suggestions would be welcome.  I have relatively few tools available out in the woods other than  jack, big wrenches, propane torch.
Thanks!
plummerscarin View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote plummerscarin Quote  Post ReplyReply Direct Link To This Post Posted: 02 Apr 2023 at 11:53am
I'm running some look way worse than that. Wouldn't scare me to air em up and roll it to a better location for service work
Post Options Post Options   Thanks (0) Thanks(0)   Quote Newwood Quote  Post ReplyReply Direct Link To This Post Posted: 02 Apr 2023 at 12:29pm
Thanks for the note:  the tires are working fine at the moment and the Allis is parked in an open shed at my hunting shack--it's just that this place is WAY out in the sticks (and under 3' of snow in Wisconsin at the moment while I'm enjoying spring in NC).   Other posts seem to suggest that getting old wheels off can be quite a challenge--so I'm looking for advice as to both if these are in such bad shape that they need to be replaced, and tips on how best to manage that (I haven't checked whether they are filled with CaCl yet either--trying to avoid getting squashed like a bug).
Post Options Post Options   Thanks (0) Thanks(0)   Quote steve(ill) Quote  Post ReplyReply Direct Link To This Post Posted: 02 Apr 2023 at 12:43pm
the spin out clamps are what they talk about being a PAIN.... Take that photo to your local tire guy and ask him if you take off the 8 center bolts and bring the tire and wheel into his shop, if he will change the tire leaving the wheel attached... Im not saying you need it done right now.... but the easy way is to remove the 8 bolts, throw the tire and wheel in the pickup, and take to the Tire Shop..... normally some kind of Farm Service Center or  Tractor Dealer can do that, and supply the tires.... check out the location  / cost / leaving rims attached before you jump in.
Post Options Post Options   Thanks (0) Thanks(0)   Quote steve(ill) Quote  Post ReplyReply Direct Link To This Post Posted: 02 Apr 2023 at 12:47pm
https://www.allischalmers.com/forum/1951-wd-9-1-volts_topic194151.html
read the last post........ internal short in generator..
Lon(MN) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Lon(MN) Quote  Post ReplyReply Direct Link To This Post Posted: 03 Apr 2023 at 5:28am
If you are good with a big hammer, Remove the eight bolts that hold the eccentrics. Hit the wheel center on the outer edge, not the rim. The rim and tire will come off along with the four eccentrics.
http://lonsallischalmers.com
Post Options Post Options   Thanks (0) Thanks(0)   Quote AC720Man Quote  Post ReplyReply Direct Link To This Post Posted: 03 Apr 2023 at 7:19am
Jack up the tractor. Since your removing the wheel for tire replacement I like making sure the eccentrics come loose and are functional first. Great time to check them. I always spray the eccentrics with some Kroil first. If you have some time, let the Kroil soak in for a half hour. Use a long bar on a socket to loosen them. I have a Milwaukee 1/2” impact gun that will spin them loose quickly. Watch the tab as they only spin 3/4 of a turn. Remove the stops on the rails also. Once they are working well tighten them back up. Then you can remove the clamps from the wheels. If time permits it’s a great time to clean up the rims after the tires are removed, bring them home and repair any damage and paint them. Much easier to do with no tires on.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Newwood Quote  Post ReplyReply Direct Link To This Post Posted: 03 Apr 2023 at 9:27am
re high generator voltage:
Steve-Yes, I had read that post a few days ago which in part prompted my question.  The troubleshooting suggested in that post was to first make sure of good ground (but like him, I think i've ruled that out). In his case it was a sudden-onset problem and appeared to be within the generator/brushes.  That may apply in my case too, although I did take a look through the inspection port and there was nothing as obvious as in his case.  But two questions still stand: 1) does changing 3rd brush position change voltage or amps (the manual doesn't provide any info on this)? 2) would installing a voltage regulator in place of the cutout control the high voltage problem?  My understanding of the physics of generators and field voltage regulation clearly needs a tune-up: the battery acts as a control on the voltage?  I've read you _can_ use 8 and 12v batteries with these generators (12v being pretty marginal and provided it's just for the starter motor and no lights involved and uses a magneto), and I believe the manual says don't run the generator without a battery (perhaps because it generates very high voltage and cooks the generator?)
re tire replacement
well I'm relieved to know everyone isn't horrified that I'm driving around on these old tires at risk of sudden death and dismemberment.  Given it's limited use and that fact that tires seem to cost as much as the tractor, i've been dragging my feet on replacing them (maybe I'm not the only foot-dragger in the AC community?).  I'm pretty sure the Allis is going to outlive me, but I'm probably not going to get another 10 years out of these tires so perhaps replace sooner rather than later?
It looks like folks use both removal strategies: removing the 8 eccentric bolts or removing the 8 central wheel bolts.  Perhaps the decision depends on which I can actually get loose.  It seems I've read struggles with both strategies: The eccentric bolts seem to be particularly hard to remove without heroic struggles (and involve some weirdness on their threading?).  And the even with central wheel bolts loose getting the wheel off the axle seems to involve hitting things with really big hammers or using piston jacks (that I don't have) to lever things off?
But, the beauty of the forum is people have figured it out multiple different ways and share the experience.  Thanks to all for any additional suggestions.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Steve in NJ Quote  Post ReplyReply Direct Link To This Post Posted: 03 Apr 2023 at 10:10am
Maximum output on a 1101413 is 10-13 amps. I usually set them up around 8-9 amps. If that unit is pushing 16+ amps, there is a problem internally and it will cook a brand new VR. It will also cook the new Ammeter and the wiring. Best to get the Gennie off and have it repaired, THEN mate a VR to the unit if you want to upgrade the 6V system. If you want to send the Gennie out to me, I can rebuild the Gennie and mate the proper VR to the unit and dial in the two on the 881 machine. Your call. You can then eliminate the 3 position switch all together is there isn't any Headlights on the Tractor. If there are headlights just use the fuse side of the switch to control the lights...  HTH
Steve@B&B
Post Options Post Options   Thanks (0) Thanks(0)   Quote AC720Man Quote  Post ReplyReply Direct Link To This Post Posted: 03 Apr 2023 at 10:31am
If your not going to have the need to spin the wheels in or out and time is limited then just Jack it up and remove the lug nuts and remove the entire assembly. Our local tire dealer removes and installs new tires with the center still attached to the spin out wheel. He has our CA rims now to replace the dry rotted tires that are way worse condition than yours. Only reason we are replacing them is the sidewalls keep pinching a hole in the tube. Otherwise they have plenty of tread on them.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Newwood Quote  Post ReplyReply Direct Link To This Post Posted: 03 Apr 2023 at 2:09pm
Steve in NJ: So like the other recent post about generator high voltage and high current that you posted on, if it's not a ground issue (something I should again recheck) it's within the 3 brush generator.  The prior poster found that pushing on a brush decreased the voltage and his description also suggested the possibility of internal short.  Is the high voltage and amps suggestive of any specific failure (e.g. 3rd brush setting, contact, or short)?  Are there any diagnostic checks (e.g. of resistance) that I can do short of rebuild/replace or switch to alternator?  I seem to recall there exists a Remi-Delco generator troubleshooting guide (from the 40s or 50s) but can't seem to track it down at the moment and I don't recall that high volt+amps was covered there.  Given that it is generating power, can you narrow the likely failure-- brush contact, 3rd brush position, brush wire short, or brush holder problem?  I'm still hoping for something I can fix myself.
Re tires, AC720man: well, they're not going flat yet (and I'm unlikely to put much wear on them at 8 hrs/year) so maybe I'll keep my fingers crossed for a bit longer--thanks for notes.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Newwood Quote  Post ReplyReply Direct Link To This Post Posted: 03 Apr 2023 at 2:20pm
I do also have a photo of the brushes:
JK in Pa View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote JK in Pa Quote  Post ReplyReply Direct Link To This Post Posted: 03 Apr 2023 at 3:51pm
Any chance the rear tires are matched and Firestones? If so I would guess they may be the originals.They will give service a long time if lightly used such as mowing. JMHO.
Post Options Post Options   Thanks (0) Thanks(0)   Quote steve(ill) Quote  Post ReplyReply Direct Link To This Post Posted: 03 Apr 2023 at 4:27pm
Jack.. i think what Steve is saying is you have a 90% chance that the problem is INTERNAL...you already checked the wires / battery / ground... same as the last guy found... It would be impossible to say if a wire came loose, a brush has bad contact, a brush is excessive worn, a brush spring broke, etc... It could be about ANYTHING inside related to the brushes... Only way to find out is to open it up and look. ..... its 60 years old... time for inspection.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Steve in NJ Quote  Post ReplyReply Direct Link To This Post Posted: 04 Apr 2023 at 8:42am
The only way to really test the unit is run it on the machine and see what the actual output is. There could be one problem such as a failed field coil, or bad com plate or the arm itself. In most cases, if the arm has never been replaced, it could have a couple open spots in it which would cause a multitude of issues. Whether you have the unit tested or checked out locally, or whether you send it to me, have the unit run tested and inspected internally to find the problem. Don't just connect new parts to that unit. It has a problem internally pushing out that kinda amperage. Tough to tell in your pic, but the com plate looks to be pretty worn.  Could be somethin' simple, or it may need a major overhaul. Ya don't know till it's put through some load tests to see what's buzzin' in there....  HTH
Steve@B&B
Post Options Post Options   Thanks (0) Thanks(0)   Quote Newwood Quote  Post ReplyReply Direct Link To This Post Posted: 04 Apr 2023 at 9:25am
Steve re charging: yes, I take your point.  But I'm trying to stay with the easy things first (and know what I'm looking for) before pulling the trigger on rebuild/replace.  I did find a wonderfully encyclopedic Delco-Remy service bulletin on generator adjustment, tests, and maintenance (http://chevy.oldcarmanualproject.com/electrical/49dr324/1g15001.htm) that I found quite informative: Since this is a 3 brush generator and the adjustable 3rd brush controls field voltage, perhaps that simple adjustment will get voltage back down.
 It's unclear to me whether this might also adjust down amps (currently putting out 7 amps when going to ground through the resistor), but I'm hoping based on Steve's comment that he "sets them up around 8 -9 amps"  that moving the 3rd brush may dial both volts and amps down ?
That would be the easy solution--but if it doesn't work then need further internal exploration.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Newwood Quote  Post ReplyReply Direct Link To This Post Posted: 04 Apr 2023 at 9:43am
Steve in NJ-- I was drafting my note before I saw your additional reply.  So (assuming the analog ammeter is correct) that's just too many amps to be a simple brush adjustment?
Post Options Post Options   Thanks (0) Thanks(0)   Quote Steve in NJ Quote  Post ReplyReply Direct Link To This Post Posted: 05 Apr 2023 at 4:56pm
That's a fact Jack!   Wink
Les Kerf View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Les Kerf Quote  Post ReplyReply Direct Link To This Post Posted: 07 Apr 2023 at 8:32am
Originally posted by Newwood Newwood wrote:
... It's unclear to me whether this might also adjust down amps (currently putting out 7 amps when going to ground through the resistor), but I'm hoping based on Steve's comment that he "sets them up around 8 -9 amps"  that moving the 3rd brush may dial both volts and amps down ?  ...
Yes, in a properly functioning system this will reduce both Volts and Amps.
Example:
Assuming a proper charging system but the battery is nearly dead (from sitting all winter, whatever) and you had to hand crank the engine to get it running. The engine starts and you let it run at high idle with the light switch nob in the High Charge position; the ammeter will show a high rate of charge but if you put a voltmeter on the battery it will read toward the low end (possibly less than 6.0 Volts) for a while until the battery gets charged up a bit; the voltage at the battery will gradually climb and the amperage will gradually reduce.
The internal resistance of a discharged battery is very low; a given Voltage will thus push more amps into the battery, as the battery charges up it will 'resist' taking in more amps, sorta like after Thanksgiving dinner and Grandma tries to get you to eat one more piece of pie, there just isn't room for any more. The pressure (Voltage, Grandma) is still high, but you (the battery) is full. The amperage (flow of food) slows down or stops completely, until there is once again room for more.
If there is a flaw inside your generator that is causing the voltage to go way too high, it is like Grandma forcing more pie down your throat; bad things may happen.
Batteries are happiest when they are just comfortably full, not too hungry and not overly stuffed. A piece of pie every day would be about ideal LOLWink
Edited by Les Kerf - 07 Apr 2023 at 8:43am
Post Options Post Options   Thanks (0) Thanks(0)   Quote AC720Man Quote  Post ReplyReply Direct Link To This Post Posted: 07 Apr 2023 at 7:08pm
Jack, new tires are on our CA. Just removed the entire wheel assembly and dropped it off at the tire shop.
200Tom1 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote 200Tom1 Quote  Post ReplyReply Direct Link To This Post Posted: 07 Apr 2023 at 8:54pm
New wood,. If you remove those tires from the tractor, be very careful. If they are full of fluid they are going to be very heavy. I owned a farm tire shop for 22 years. I can assure you the easiest way to replace tires on a farm tractor is doing it with the rims on the tractor. It's far easier than you removing the rims and tires and taking them to a tire shop.
FloydKS View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote FloydKS Quote  Post ReplyReply Direct Link To This Post Posted: 08 Apr 2023 at 6:52am
For what it is worth.... I have a WD-45 with tires in the same condition. They have been that way, cracked, for more than a couple of years and I have no intention of changing them. It is only used for very light work ... a wagon for hay rack rides and an Oxnard blade that I play with on my one acre yard with an occasional use of a Bush Hog mower that I had when on the farm as a kid.    SO   my opinion is do not worry at this point ... and as has been mentioned there are trucks that can come and do the tire work for you if you 'pay the piper'.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Newwood Quote  Post ReplyReply Direct Link To This Post Posted: 08 Apr 2023 at 1:59pm
Les re charging system: Well, it doesn't seem that my case is associated with degree of battery discharge (battery is at good voltage before starting tractor, is high during operation, and is high but not excessive after use and turning off).  At this point I'm mostly trying to educate myself on how these 3 brush systems work -- mostly I can't resist believing that this presents a solvable diagnostic puzzle if only I can fully understand thing down at the first principles level.  So the 3rd brush controls current flow through the fields to ground, and moving that brush in the direction of rotation increases field current while moving other direction decreases field current (and thus drops both voltage and amps).  I haven't tried adjusting that 3rd brush to decrease that, but Steve in NJ who has a much deeper knowledge base than me doubts that will be sufficient to correct.  If the 3rd brush wire is shorted against the casing I don't think there would be any field current.  The field to ground with and without resistor is working as it should (increasing and decreasing voltage) so shorts in the field circuit seem less likely.  This only has a cutout, so there's no voltage regulator in the mix of possibilities.  I suspect Steve would agree with an old surgeons saying: "don't let a little skin get between you and and a diagnosis" but I'm not a surgeon (and I can't lay hands on the tractor for a while yet) so puzzling through how things should work and how things could fail and give this particular result remains an interesting puzzle to me.  Grandma's cooking might certainly offer a welcome distraction!
200tom1 and floyd: yeah, having someone come out and change them while still on the tractor was part of my original question--I have been searching for a place that does that in one of the towns around (between Merrill and Rib Lake Wisconsin) but I wasn't finding anything and as I said, this is a ways off the beaten track (and I don't have a trailer to move the tractor to a tire place).  But I'm encouraged that others are still running on similar cracked rubber, so hope springs eternal that I can continue to whistle past the tire graveyard.  But I may be whistling another tune soon enough if I get a flat, so I appreciate the inputs.
KJCHRIS View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote KJCHRIS Quote  Post ReplyReply Direct Link To This Post Posted: 08 Apr 2023 at 2:49pm
It's been 45-50+ years ago. But I remember grandad playing with generator and its relay on customer tractors to up the voltage to fully charge an 8-volt battery to help with cold weather starting. But if remembering right when volts went up the amperes went down.
  Is it possible this is a similar situation?
 Me, I'd take generator and relay/regulator to a repair shop that can run them as a set on a tester. That would verify if your readings are correct or not. For 20+ years I've had 3 D series tractors with 12V positive ground generators and regulators, I've never had to do any repairs on them so am out of practice.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Les Kerf Quote  Post ReplyReply Direct Link To This Post Posted: 10 Apr 2023 at 11:42am
...  At this point I'm mostly trying to educate myself on how these 3 brush systems work -- mostly I can't resist believing that this presents a solvable diagnostic puzzle if only I can fully understand thing down at the first principles level...
As an old avionics tech I always want to know the root cause of failure, even if there is nothing I can do about it. Here is a link to the best description I have found on Third-Brush theory of operation.
https://automotiveenginemechanics.tpub.com/TM-9-8000/TM-9-80000307.htm
...  If the 3rd brush wire is shorted against the casing I don't think there would be any field current...
No, quite the opposite in fact. The generator armature is the source of the field current which is ultimately grounded at the light switch. If the third brush wire shorts against the casing then it will effectively bypass the resistance in the light swich, causing the generator to be "full-fielded' and thus at maximum output.
... so puzzling through how things should work and how things could fail and give this particular result remains an interesting puzzle to me...
If I were troubleshooting this system the first thing I would want to check is the field current measured at the light switch and monitor it and voltage as the system warms up.
Here are a couple more relevant links:
http://dueyschutter.freeservers.com/photo5.html
http://vias.org/kimberlyee/ee_31_02.html
Post Options Post Options   Thanks (1) Thanks(1)   Quote Newwood Quote  Post ReplyReply Direct Link To This Post Posted: 10 Apr 2023 at 2:20pm
Les:  That first link you provided is really wonderful -- and by going to other sections of the link/manual provides remarkably clear descriptions of magnetism, induction of currents in a wire and armature winding and construction.  Really nice, clear, and concise.  It even made me appreciate the application of ohms law to this particular problem--which as you pointed out in your earlier post means that if resistance in the circuit stays the same, then adjusting the 3rd brush will decrease both voltage and amps.  Good stuff.  Thanks.
re 3rd brush short: yes, and the other evidence against that is that going through the resistor at the light switch does indeed change the amps from lower to higher which wouldn't have an effect if there was a short.
Re voltage/amp data.  I recorded some measurements but my notes aren't comprehensive.  With tractor off the battery reads 6.5 v.  At a normal working RMP continues to increase to 8.6v and ~7amps when going through the resistor and when light switch pulled out so going directly to ground (there are no lights on this tractor) goes to 8.9v and ~17amps.  Immediately after running with engine off battery reads at 7.17v.  Volts are measured digitally and amps via new analog -20 to 20 ammeter on dash. I'm confident of the accuracy of the voltmeter, but not necessarily confident about the accuracy of the ammeter.  In case anyone is wondering, this is a 6v battery and fluid levels have been fine (somewhat surprising to me since I was concerned I'd boil it off after running for hours charging at that rate).
I'm used to things failing -- this one just has particularly puzzled me because of it's apparent _increased_ performance and it's always nice to go in with a working hypothesis for what I'm looking for.
Thanks again for the informative link.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Les Kerf Quote  Post ReplyReply Direct Link To This Post Posted: 11 Apr 2023 at 10:48am
This, the field current is the crucial measurement needed; an ammeter capable of measuring ~20 amps will be necessary.
Re voltage/amp data.  I recorded some measurements but my notes aren't comprehensive.  With tractor off the battery reads 6.5 v.  At a normal working RMP continues to increase to 8.6v and ~7amps when going through the resistor and when light switch pulled out so going directly to ground (there are no lights on this tractor) goes to 8.9v and ~17amps.  Immediately after running with engine off battery reads at 7.17v.  Volts are measured digitally and amps via new analog -20 to 20 ammeter on dash. I'm confident of the accuracy of the voltmeter, but not necessarily confident about the accuracy of the ammeter...
Your in-dash ammeter is adequate for this task; absolute precision is not needed and your amp readings are reasonably in accord with your voltage readings.
Quoting from the manual (emphasis mine):
"Because the third-brush generator depends upon
the current flowing through the armature winding to
produce the field distortion necessary for regulation, it is
obvious that it is current-regulated internally (as distinct
from external current regulation). Therefore, it must
have a complete circuit available through the battery at
all times. Otherwise, regulation would be destroyed and
excessive field currents would burn out the generator
windings. The generator terminals must be grounded in
case the third- brush generator is disconnected from the
battery.
"The third-brush generator provides current
regulation only and does not take battery voltage into
consideration. In fact, a fully charged battery that has a
high voltage actually will get more current from a third-
brush generator
than a battery that is completely
discharged, because the high voltage holds up the
voltage at the generator, makes the field stronger, and
causes the generator output to increase."
I gave you some incorrect information in an earlier reply based upon my incomplete understanding of how a third-brush type generator is regulated.
According to this manual, and I believe it is correct, a higher load resistance (a fully charged battery presents a higher load resistance) results in an increase in field current which results in higher voltage and current, which results in higher field current which results in higher.... Tongue
Poor battery connections, poor cables, poor grounds, etc. will increase the load resistance; disconnecting the battery completely creates an infinitely high load resistance, which causes the generator to run away to self-destruction.
Prior to reading this manual and thus furthering my education I would have never  believed it to be appropriate to actually, deliberately, on purpose ground the output of any generator.
You are most welcome, I truly enjoy digging in to this kind of stuff Smile
Post Options Post Options   Thanks (0) Thanks(0)   Quote Newwood Quote  Post ReplyReply Direct Link To This Post Posted: 11 Apr 2023 at 1:08pm
Les
The bit from the manual about "the generator terminals must be grounded if the 3rd brush generator is disconnected from the battery" takes some interpretation.  I imagine this also relates to a warning about running the tractor without a battery (which you could do using the crank to start) or if you disconnected the battery while it was running.  But it seems like a puzzling recommendation doesn't it?  Removing the connection between the field terminal and ground (which is how the tractors were shipped from the factory) would seem to do the trick:  you can't set up a field current if that terminal isn't connected, so the generator can't generate anything without it.  I seem to recall from some other thread someone suggesting just such a disconnect as a temporary solution to overcharging (e.g. if resistor has burned out, you could use a simple toggle to either allow or not allow the field terminal access to ground).  Am I missing something here?  Running the tractor and generator with the field terminal disconnected would seem to put the generator at no risk.
The fully charged battery/high resistance leading to even higher field and higher voltage has got to have some other limits (otherwise all these generators would be increasing voltage/current in an out of control feedback loop).  Perhaps part of the rationale for developing actual voltage regulators, followed by subsequently dumping the whole generator for alternators.
Who knew I'd be learning so much electrical theory to mow some roads?!
Post Options Post Options   Thanks (0) Thanks(0)   Quote Les Kerf Quote  Post ReplyReply Direct Link To This Post Posted: 12 Apr 2023 at 11:19am
I'm still not quite ready to deliberately ground the armature of this generator Confused
The word "terminals" is plural; there are only two terminals, and if the field terminal is grounded the generator will attempt to produce maximum current, which would then put this amount of current directly to ground. I do not like this idea. Shocked
I agree.
There will be some current generated due to the residual magnetism in the field coils, perhaps this small amount of current should be grounded?
Yup, you got it! This system was the lowest-cost solution at the time and was adequate for a tractor that would typically be started in the morning, ran until noon dinner, then re-started and ran until evening chore time.
I suspect that the field coils in your tractor are partially shorted out internally, resulting in higher field current than normal. This is why I keep going back to measuring your actual field current.
The WD/WD45 shop manual specifies 3.5-4.5 amps of field current @ 6 Volts, with an output of 10-13 amps @ 7.4-7.7 Volts Hot.
You could reduce the field current by installing an ignition ballast resistor in the field circuit, but best practice would be to replace the field coils if they are bad.
I too have learned something; I have been an electronics tech since the 1970's and have a pretty good grasp on this stuff, but I had never before delved into the peculiarities of the Third Brush generators. This has been fun Smile
Post Options Post Options   Thanks (1) Thanks(1)   Quote Newwood Quote  Post ReplyReply Direct Link To This Post Posted: 17 May 2023 at 1:37pm
Just a followup note to anyone who likes to read to the bitter end.  I got back to Wisconsin and cleaned up all the contacts hoping that would fix things, but no joy.  Second step was to adjust the 3rd brush, which did indeed bring down the amps to around 2 with resistance and 7 going directly to ground, but voltage was still over 8.  So I pulled the generator (and my battery) and took them in to P J Rebuilders in Wausau Wi (fabulous place) where after extensive bench testing (including directly to my battery and in independent tests to the bench battery system), found that everything was OK.  Subtle 3rd brush changes could lead to quite high amp output (20 amps), but managed to get it tuned in to around 7.4v and 9 amps when going directly to ground, and when hooked back up to my tractor and going through the resistor 7.1v and 3 amps.
Now on to the mystery of how 7 gal of fuel disappeared over the winter despite a closed stopcock.  The adventures continue...
This page was generated in 0.168 seconds.
