Loader wanted
Roach View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Roach Quote  Post ReplyReply Direct Link To This Post Topic: Loader wanted
    Posted: 30 Mar 2023 at 3:49pm
Friend of mine is looking for a good used front-end loader for his 180. Does not have to be Allis but does need all mounting brackets. No trip bucket. Hopefully somewhere in the south central Illinois area.
Thanks in advance.
1937 WC, 1948 G,1954 CA,1956 WD45, 1967 D17, 1937 M crawler, 1963 D-19, 1966 190XT, 1967 D-15, 1948 HG42 Cletrac, 1955 G456 Terra Trac, CAT 10 1928 and CAT 22 1938
troym View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote troym Quote  Post ReplyReply Direct Link To This Post Posted: 31 Mar 2023 at 7:10am
i would have a  loader on a 185 I'm junking se corner of Minnesota, 507 421 0213
Post Options Post Options   Thanks (0) Thanks(0)   Quote Roach Quote  Post ReplyReply Direct Link To This Post Posted: 01 Apr 2023 at 11:16am
troym, thanks for the response and even though you are pretty far away, we will keep you in mind.
190XTLP View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote 190XTLP Quote  Post ReplyReply Direct Link To This Post Posted: 01 Apr 2023 at 5:06pm
I have a allis 500 on a XT taking it off works fine 500
00 takes it
WD45G,WD45D.190XTD,190XTLP
D19LP,WC unstyled,WF unstyled
WC styled,220
Post Options Post Options   Thanks (0) Thanks(0)   Quote 190XTLP Quote  Post ReplyReply Direct Link To This Post Posted: 01 Apr 2023 at 5:07pm
618 535 1155
WC styled,220
Don Jr NY View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Don Jr NY Quote  Post ReplyReply Direct Link To This Post Posted: 02 Apr 2023 at 4:36am
Just so you are aware the rear mounting brackets are different for the 180/185 vs the 190xt. the 190xt has planetary drive straight axles and the 180/185 have the drop boxes so the rear brackets are straight back to the rear axle with square U bolts on the 190 and they angle up to the rear axle with round U bolts on the 180/185. Hope this helps.  Don Jr.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Roach Quote  Post ReplyReply Direct Link To This Post Posted: 02 Apr 2023 at 11:51am
Thanks for the info Don. trying to figure out what it would take to modify it to work.
Appreciate the heads up.
Rick
