190xt turbo oil elbow not sealing |
Post Reply |
youngorange2000
Silver Level Joined: 27 Mar 2019 Location: eastcentral MN Points: 310 |
Posted: 28 Mar 2023 at 4:38pm |
The brass elbow on top of my turbo is leaking I have it as tight as I can and still have it pointing the right way for the oil line. Is there something I could use that's oil and heat proof to seal it with? Thanks
JPG AUSTRALIA
Orange Level Joined: 13 Sep 2009 Points: 756 |
Thread on elbow most likely has a crack through it,
Edited by JPG AUSTRALIA - 28 Mar 2023 at 5:50pm |
MACK
Orange Level Joined: 17 Nov 2009 Points: 7664 |
I would use red loctite and a new rubber on line. MACK
KJCHRIS
Orange Level Joined: 21 Dec 2015 Location: WC Iowa Points: 904 |
Double check where oil come up & out at threads into turbo housing OR is the fitting itself cracked OR at threads the line couples with?
I've seen all 3 leak, have used 1 1/2 wrap of teflon sealing tape on male thread w/ no isssues.
youngorange2000
It is coming from turbo housing threads
DrAllis
Orange Level Access Joined: 12 Sep 2009 Points: 20496 |
If it's coming from the pipe threads, it needs some kind of goop or thread tape on the threads and brake kleen both the hole and the male threads before assembly. And it has to be tight enough !!
youngorange2000
Is it safe to use regular pipe tape with it going into the turbo? Fully tight puts the outlet of the elbow where the line will not work
SteveM C/IL
Orange Level Access Joined: 12 Sep 2009 Location: Shelbyville IL Points: 8239 |
Regular teflon tape. Just be sure to keep back from edge of thread so none can get into oil.
DrAllis
Can't get the tube connected to it ?? Why? orientation wrong ?? tighten it more. Too far down to not be able to connect the tube ?? Get a NEW elbow fitting that has new threads and it will sit up a little higher.
injpumpEd
Orange Level Access Joined: 13 Sep 2009 Location: Walnut IL Points: 4912 |
The bad part about pipe threads and a 90* fitting. Aimed right almost hand tight, by the time you make another round it gets so tight you feel like it'll break! If you use tape, use caution too. It's so slick it'll turn easier.
HudCo
Orange Level Joined: 29 Jan 2013 Location: Plymouth Utah Points: 3539 |
every one is right, i would try a new fitting and use loctite 545 hydralic and phenmatic sealer is some very good stuff for some of those problem npt fittings it has high solids in it and is rated for extreme temps if its assembled clean and it can set for a day it can handle 2000psi , but it disasembles like red 270 loctite 545 might only be available through an industrial supplyer like grainger . also if you have a cracking in your female threads it might take it up.
Post Reply | |
