D14 Transmission
Puryear View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Puryear Quote  Post ReplyReply Direct Link To This Post Topic: D14 Transmission
    Posted: 13 Oct 2010 at 11:17pm
Just bought a 1958 D14 and was wondering if they all have low/high range transmissions. Mine has a shift position sticker that shows 8 speeds, but I do not see a lever to switch between the 2 ranges? Also, I need to get the sideplates that go under the tank behind the instrument cluster. Does anyone know where to purchase those. Thanks!
darrel in ND View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote darrel in ND Quote  Post ReplyReply Direct Link To This Post Posted: 13 Oct 2010 at 11:31pm
I think all D 14's had 2 ranges, called  power director. Shifter should be big tall lever on the right hand side
Post Options Post Options   Thanks (0) Thanks(0)   Quote Puryear Quote  Post ReplyReply Direct Link To This Post Posted: 14 Oct 2010 at 12:15am
Darrell, I thought that was just what I call the hand clutch? There is a push button on top of it. I had a WD with a hand clutch and it did not have that button on top. Does that have something to do with it?
Post Options Post Options   Thanks (0) Thanks(0)   Quote Brian Jasper co. Ia Quote  Post ReplyReply Direct Link To This Post Posted: 14 Oct 2010 at 6:47am
Yes. The WD's hand clutch was just an in and out. On the D14 it is a high, neutral, and low. Push it all the way forward for high, pull it all the way back for low. Neutral is in the middle. Over the years the latch plate wears and you probably don't need to hold the button down to shift it anymore.
GregLawlerMinn View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote GregLawlerMinn Quote  Post ReplyReply Direct Link To This Post Posted: 14 Oct 2010 at 7:30am
You can obtain the undertank covers from Norm, Doc, Tny C, and maybe a few more of the fine Suppliers who sponsor this site.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Puryear Quote  Post ReplyReply Direct Link To This Post Posted: 14 Oct 2010 at 7:32am
Thanks much, I had no idea it worked like that.
Post Options Post Options   Thanks (0) Thanks(0)   Quote darrel in ND Quote  Post ReplyReply Direct Link To This Post Posted: 14 Oct 2010 at 8:01am
The button on top of the lever locks it in neutral popsition, and it should snap into low (back) and high (ahead). You can change from high to low just like a power shift (on the go with no clutching) and also use the neutral psition for live PTO.. Darrel
Post Options Post Options   Thanks (0) Thanks(0)   Quote Puryear Quote  Post ReplyReply Direct Link To This Post Posted: 14 Oct 2010 at 9:07am
Thanks again! Mark
