Allis Chalmers 5020 operation |
Post Reply ![]() |
iorior ![]() Bronze Level ![]() Joined: 22 Mar 2023 Location: GA Points: 9 |
![]() ![]() ![]() ![]() ![]() Posted: 22 Mar 2023 at 4:53pm |
Edited by iorior - 22 Mar 2023 at 6:38pm |
steve(ill) ![]() Orange Level Access ![]() ![]() Joined: 11 Sep 2009 Location: illinois Points: 88225 |
some have the Creeper... some do not...
is the "S" a neutral start position ? Where is the shift lever when you start it ?
Shift pattern looks like this: R 1 3
S 2 4. I wish there was a way to attach a picture.
im4racin ![]() Orange Level ![]() Joined: 12 Jun 2017 Location: Garrison ND Points: 1068 |
S is the start position. My guess is the safety switch was bypassed. The m l h is low medium and high range box, bit round knob in that picture. Down for medium and up for high. Knob under seat is suspension firmness for the seat. Turn to adjust.
BrianC ![]() Orange Level Access ![]() Joined: 16 Jun 2011 Location: New York Points: 1619 |
I was thinking the F,S L knob should be for 3pt arms speed. Fast, Slow, Lock? My old Ferguson TO-20 had an S position on the gear shift. It activated the starter.
Also to answer your question, the gearshift is dead center between 1 and 2 when I start...that's neutral
This starter is key activated.
Thanks...that knob was confusing as it appears to go into the gearbox. Do any of these levers engage/disengage 4WD?
Yes I think you are right on 3pt speed. My mistake
Lever right under seat is 4wd. It's the one that hits the seat pan when up. Up is 2wd down is 4wd
Thanks. That's the lever which seems to correspond to the embossed letters "F" and "S" which probably mean fast (2WD) and slow (4WD) with a letter "L" below which I don't understand. Or maybe those letters refer to the seat firmness knob and indicate "firm, soft and something else? At least I now know up is 2WD and down is 4WD...it comes close but doesn't hit my seat pan when up. Thanks again
Jim.ME ![]() Orange Level ![]() Joined: 19 Nov 2016 Location: Maine Points: 962 |
I believe the knob is turned to adjust the speed the three point arms lower. Turn towards F for faster, S for slower, turned fully clockwise the valve is closed and the arms will not lower (L).
I suggest you invest in an Operator's Manual, sooner rather than later.
Edited by Jim.ME - 23 Mar 2023 at 6:57am |
Thanks Jim...Unfortunately, the knob wont budge and since I'm happy with lift speed I'm not going to force it (parts are hard to come by for this tractor). I'm thinking now that the lever to the left of the knob is to switch between 2WDand 4WD...your thoughts? Just realized someone answered that question and it is for drive wheels. Also, am looking for a good owners manual...some on ebay seem to be scam-like. Thanks again for your response.
Edited by iorior - 23 Mar 2023 at 8:14am |
Just ordered the first one listed, thanks
TramwayGuy ![]() Orange Level Access ![]() Joined: 19 Jan 2010 Location: Northern NY Points: 11763 |
You have the 12-speed transmission. Early tractors had only 8; with a fairly large jump between high and low ranges. I have a 5030 with the 8-speed and I wish I had the later one.
Post Reply ![]() |
