D15 series 1 steering u joints
dale melenia View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote dale melenia Quote  Post ReplyReply Direct Link To This Post Topic: D15 series 1 steering u joints
    Posted: 21 Mar 2023 at 6:36pm
How does the steering linkage come apart to replace the mid u joint? This is a D15 diesel series 1.
DonDittmar View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote DonDittmar Quote  Post ReplyReply Direct Link To This Post Posted: 22 Mar 2023 at 11:31am
If I remember right, the lower shaft slides forward in the splined coupling at the gearbox. you then grind of the peened over pins and drive them out to get the yokes off.
I did this on my dads D17 years ago, and when I did it I bought the 2 yokes and ujoint together from Brenda at Sandy Lake cheaper than AGCO wanted for just the ujoint
1968 D15D,1962 D19D
Post Options Post Options   Thanks (0) Thanks(0)   Quote dale melenia Quote  Post ReplyReply Direct Link To This Post Posted: 22 Mar 2023 at 7:39pm
I will take a closer look at that. Thanks for the information.
Post Options Post Options   Thanks (0) Thanks(0)   Quote DrAllis Quote  Post ReplyReply Direct Link To This Post Posted: 22 Mar 2023 at 8:04pm
Hammer out both Ujoint yoke pins.  This takes 3 or 4 lb hammer, a proper sized punch and grind off the pins end flush with the yoke. With the engine off, turn the steering wheel hard both ways and break one shaft loose inside of its yoke. Re-install that pin and continue turning the wheel until the other yoke breaks free. Lots of penetrating oil and maybe things will slide apart.
Edited by DrAllis - 22 Mar 2023 at 8:19pm
This page was generated in 0.150 seconds.
