Duetz-Allis 9150
JC-WI View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote JC-WI Quote  Post ReplyReply Direct Link To This Post Topic: Duetz-Allis 9150
    Posted: 19 Mar 2023 at 12:47pm
Are they a good tractor? Worth looking at?
cwhit View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote cwhit Quote  Post ReplyReply Direct Link To This Post Posted: 19 Mar 2023 at 12:56pm
Yes
Post Options Post Options   Thanks (0) Thanks(0)   Quote SteveM C/IL Quote  Post ReplyReply Direct Link To This Post Posted: 19 Mar 2023 at 1:37pm
I know nothing about them. If they have the solenoid trans controls with the Funk trans,I've heard unsettling stories about reliability and finding-fixing problems. Nothing wrong with the mechanicals just the electronics. Do your homework!
Edited by SteveM C/IL - 19 Mar 2023 at 1:38pm
bigal121892 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote bigal121892 Quote  Post ReplyReply Direct Link To This Post Posted: 19 Mar 2023 at 2:24pm
The 9100 series are a White tractor with a Deutz engine. We had one for a while, very easy on fuel, good torque, drive train is rock solid, over all a very good tractor. Just be sure and keep the engine clean, since they are air cooled, and proper air flow is vital.
What SteveM is talking about is a 9650/9655, which is a Deutz or Detroit Diesel, w/Funk transmission and a white rear end. Biggest problem with this series, is agco pretty much abandoned them, which was their biggest problem.
Edited by bigal121892 - 19 Mar 2023 at 2:35pm
Post Options Post Options   Thanks (0) Thanks(0)   Quote DrAllis Quote  Post ReplyReply Direct Link To This Post Posted: 19 Mar 2023 at 2:33pm
They were fine and pretty rugged. BUT, if you had a big Allis-Chalmers with a Power Shift transmission, it was kind of a step backwards.
8070nc View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote 8070nc Quote  Post ReplyReply Direct Link To This Post Posted: 19 Mar 2023 at 7:01pm
I agree with the good Dr
We rented a 9170 one year
Ill take a 8070 any day
1984 80780
1957 D14
DES 300 with 25000 engine
616 tractor
Joe Goodwill View Drop Down
Bronze Level Access
Bronze Level Access
Post Options Post Options   Thanks (0) Thanks(0)   Quote Joe Goodwill Quote  Post ReplyReply Direct Link To This Post Posted: 19 Mar 2023 at 7:14pm
Solid drivetrain, keep the heads clean. Some visibility and cab control placement but if the price is right they are reliable horsepower.
Post Options Post Options   Thanks (0) Thanks(0)   Quote DrAllis Quote  Post ReplyReply Direct Link To This Post Posted: 19 Mar 2023 at 7:33pm
It was just a shame that the Deutz people scrapped the A-C 8000 chassis and cab and had to outsource a chassis/cab from White to stick their engine into.
Post Options Post Options   Thanks (0) Thanks(0)   Quote bigal121892 Quote  Post ReplyReply Direct Link To This Post Posted: 19 Mar 2023 at 8:02pm
Well, you know what they say, "You can always tell a German, just can't him much".
victoryallis View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote victoryallis Quote  Post ReplyReply Direct Link To This Post Posted: 19 Mar 2023 at 8:43pm
I’ve seen enough headaches that it would have to be priced near salvage value before I’d consider it.
Post Options Post Options   Thanks (0) Thanks(0)   Quote JC-WI Quote  Post ReplyReply Direct Link To This Post Posted: 20 Mar 2023 at 2:28am
Thanks fellas for the info, it has been on a lot for awhile, other than moved to mow where it sat last year.
Post Options Post Options   Thanks (0) Thanks(0)   Quote DrAllis Quote  Post ReplyReply Direct Link To This Post Posted: 20 Mar 2023 at 6:34am
Be sure to notice upon a cold-start fire up, if there is ANY popping sound that comes from the engine. It may only do it 2 or 3 times and immediately go away. If so, that is a blown "head gasket" on one jug. I had one combine years ago that gave trouble and one 9650 tractor that did a similar thing. No trouble with dozens of other engines. Both of these operators could break an anvil with a small ball peen hammer.
6080fwa View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote 6080fwa Quote  Post ReplyReply Direct Link To This Post Posted: 20 Mar 2023 at 8:10am
U need to try it before u buy it and work it hard when it is hot outside to be sure tranny/engine tractor has no issues..... they are  a solid tractor if looked after but a operator who is abusive and not willing to maintain the deutz engine meticulously should not buy this tractor as they need to be maintained properly and most people dont do that.  Get the fwa version pulls like a freight train.  not a good chore tractor ,best used  for field work. when driving down hills be in direct.   Whites powershift tranny is as good as or better than anyone elses of the time.  they are 30 years old! i own two of them and would not trade them.......
d19d d19lp 175d 190d 190gxt 190dxt 200 6080 7000 8010 9150 9190
AllisandGleaner View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote AllisandGleaner Quote  Post ReplyReply Direct Link To This Post Posted: 20 Mar 2023 at 8:14pm
There is a lot of iron in them tractors I’ve got a 9130 I wouldn’t trade for a 4455 Deere everything’s built heavier. Keep the engine clean and don’t forget the over under when servicing them tractors will run forever.
