fine tuning new distributor ?
 Rating: Topic Rating: 1 Votes, Average 4.00  Topic Search Topic Search  Topic Options Topic Options
sunsation288 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote sunsation288 Quote  Post ReplyReply Direct Link To This Post Topic: fine tuning new distributor ?
    Posted: 16 Mar 2023 at 5:16pm
Hello all , i am so excited , i have change my carburator 2 week ago , and today put my new electronic distributor  ( bought from steve) , my tractor run very well and easy to start  , my only concern when i shut it down sometime he do a little back fire ? i pretty sure   it's timing related  , what the best way to do the fine tuning of  timming ? with a timing light ?
i am so happy to have my grand pa tractor
Ed (Ont) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Ed (Ont) Quote  Post ReplyReply Direct Link To This Post Posted: 16 Mar 2023 at 5:58pm
Time it with a light. Has to be timed at 3/4 throttle or more. Lay on your back and have a helper turn distributor up top. Time it to the "F" mark on the flywheel. It has to be straight down and line up with the little cast pointer in middle  of inspection hole. Smile
Edited by Ed (Ont) - 17 Mar 2023 at 8:00am
Post Options Post Options   Thanks (0) Thanks(0)   Quote steve(ill) Quote  Post ReplyReply Direct Link To This Post Posted: 16 Mar 2023 at 5:59pm
do you have a timing light (tool)?
assume you installed and timed ADVANCE at the FIRE mark ? ..... or just STATIC  before TDC ?
Edited by steve(ill) - 16 Mar 2023 at 6:02pm
Post Options Post Options   Thanks (0) Thanks(0)   Quote sunsation288 Quote  Post ReplyReply Direct Link To This Post Posted: 21 Mar 2023 at 7:01am
thanks all for your help , with the timing light i was able to align the F mark
the tractor run great !!!
god bless you all
long live to this forums
Post Options Post Options   Thanks (0) Thanks(0)   Quote DrAllis Quote  Post ReplyReply Direct Link To This Post Posted: 21 Mar 2023 at 7:07am
I hope you did it with the engine at wide open throttle.
Clay View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Clay Quote  Post ReplyReply Direct Link To This Post Posted: 21 Mar 2023 at 2:41pm
The 500 loader frame make it almost impossible to shine a timing light into the hole on my D-17.  Any good tips?
Post Options Post Options   Thanks (0) Thanks(0)   Quote DrAllis Quote  Post ReplyReply Direct Link To This Post Posted: 21 Mar 2023 at 5:43pm
A clean mirror and a clean mark on the flywheel.
Clay View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Clay Quote  Post ReplyReply Direct Link To This Post Posted: 21 Mar 2023 at 10:41pm
Thanks DrAllis, that is what I had envisioned.  Just was wondering what others had done.
Stan R View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Stan R Quote  Post ReplyReply Direct Link To This Post Posted: 22 Mar 2023 at 6:25am
On our D17, I pull the 2 bolts on the support by the engine (timing hole side only) and lift the bucket a bit and the bucket frame drops enough to get a clean shot at the timing hole. But its a Schwartz loader so may not work on yours.
Edited by Stan R - 22 Mar 2023 at 6:27am
