Help with searching on the forum.
brkfldj View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote brkfldj Quote  Post ReplyReply Direct Link To This Post Topic: Help with searching on the forum.
    Posted: 15 Mar 2023 at 4:16pm
Is there a filter system that will take me to my previous posts? If so, I haven’t been successful at identifying the path. I would like to post a follow up.
Thanks.
Jim
Democracy is two wolves and a lamb voting on what is for lunch. Liberty is a well-armed lamb contesting the vote. ——— Ben Franklin
Post Options Post Options   Thanks (0) Thanks(0)   Quote steve(ill) Quote  Post ReplyReply Direct Link To This Post Posted: 15 Mar 2023 at 4:28pm
at the top of the page, click on SEARCH... then type in  "DISC" or "HYDRAULIC" or what ever the topic was and it will show you a list of past topics for EVERYONE
Post Options Post Options   Thanks (0) Thanks(0)   Quote steve(ill) Quote  Post ReplyReply Direct Link To This Post Posted: 15 Mar 2023 at 4:30pm
If you want to see only YOUR posts, then LEFT click on your name in your post above and get the small DROP DOWN BOX... Then click on MEMBERS POSTS.... then fill in the TOPIC.( like "DISC".). and your NAME should be on the right.
Edited by steve(ill) - 15 Mar 2023 at 4:32pm
Post Options Post Options   Thanks (0) Thanks(0)   Quote brkfldj Quote  Post ReplyReply Direct Link To This Post Posted: 15 Mar 2023 at 6:39pm
Thank you, steve(Ill), I do appreciate your willingness to help so many of us. I did find the post that I was looking for and posted an update.
Jim
WF owner View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote WF owner Quote  Post ReplyReply Direct Link To This Post Posted: 15 Mar 2023 at 9:39pm
I have the best luck by using Google. I search for Allis Chalmers Forum and what I'm looking for like Allis Chalmers Forum 180 front wheel bearings.
Post Options Post Options   Thanks (0) Thanks(0)   Quote allischalmerguy Quote  Post ReplyReply Direct Link To This Post Posted: 19 Mar 2023 at 4:13pm
You can also go to Google advanced search. I find it easier to find things there since you can chose exact phrase
https://www.google.com/advanced_search
[URL= ][/URL]
Once you get there the first three lines you can fill in your search either an exact phrase or the first line put what words you want to find.
Just use one of the first three lines not all three. Most of the time I put my search in exact phrase line like WD brakes or D17 Seat you get the idea.
For the domain line down farther in the page type - https://www.allischalmers.com/forum/
When you have those two lines filled out click in the Advanced Search blue button on the page. Good luck
Edited by allischalmerguy - 19 Mar 2023 at 4:14pm
ACinSC View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote ACinSC Quote  Post ReplyReply Direct Link To This Post Posted: 19 Mar 2023 at 4:40pm
I found that I can go to control panel and then subscription and see every post I have commented on. HTH
