D17 Front Bolster worn out |
New Allis Fan
Joined: 06 May 2022 Location: Upstate ,NY Points: 32 |
Topic: D17 Front Bolster worn outPosted: 14 Mar 2023 at 7:08pm |
Hello ,looking for a good condition front bolster to fix my D17 ,Front pivot pin area is wire thru . Does anyone have one for sale ? It is a wide front series 4 . Thanks
Tracy Martin TN
Joined: 11 Sep 2009 Location: Gallatin,TN Points: 10937 |
Posted: 14 Mar 2023 at 8:34pm |
Post a pic of the worn area. It might can be repaired. Tracy
New Allis Fan
Posted: 14 Mar 2023 at 8:37pm |
Ok Tracy ,it is the worst I have seen ,I can weld it up
And send to a machine shop ,but I’m wondering if anyone has a good one . I’ll post pics tmrw . Thanks John |
DrAllis
Posted: 14 Mar 2023 at 8:39pm |
Doubtful that you will find one as nice as a good machine shop fix. They are ALL 60 years old !!
Edited by DrAllis - 14 Mar 2023 at 8:40pm |
Clay
Joined: 11 Sep 2009 Location: Udall, Kansas Points: 10413 |
Posted: 14 Mar 2023 at 8:44pm |
I repaired the pivot in my D-17 over 25 years ago. Used Belzona 1111 Super Metal to fill the void surrounding the pivot bushing. Welded a new pivot pin to the wide front end.
We use the D-17 for field work and use the 500 loader for all sorts of heavy work. |
DSeries4
Joined: 12 Sep 2009 Location: Ontario, Canada Points: 7639 |
Posted: 15 Mar 2023 at 4:40pm |
x2!
New Allis Fan
Posted: 20 Mar 2023 at 7:22am |
Update : I actually found one in good condition ,someone had drilled and tapped it for a grease fitting ,I’m going to install a new bushing but the casting has not been touched . Lucky find ! Thanks for the replies.
