Help I took the frugality too far
Thad in AR. View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Thad in AR. Quote  Post ReplyReply Direct Link To This Post Topic: Help I took the frugality too far
    Posted: 14 Mar 2023 at 7:01am
I just built a room in my shop to house our freezers.
It’s insulated and going to have a mouse proof exterior door.
I priced 36” steel exterior doors and sticker shock scared me away.
I went to a local used store last night and found exactly the door I want with left hand swing and all. They said they would take $30.00 I bought it.
This door had something glued to the surface. They used silicon and spread it with a 1/8” notched trowel. I tested a couple spots and it was peeling of very easy.
I got it home and hung the door. After I was satisfied with the installation I begun the process of removing the silicon.
It doesn’t peel off everywhere as easy as it did in my test spots.
Any advice on this?
Has it on both sides.
Also silicon peelings sure don’t sweep up easily either.
Anything soften cured silicon?
Post Options Post Options   Thanks (0) Thanks(0)   Quote DMiller Quote  Post ReplyReply Direct Link To This Post Posted: 14 Mar 2023 at 7:18am
Enamel Reducer.  Go to a local body shop, buy what they use.
8070nc View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote 8070nc Quote  Post ReplyReply Direct Link To This Post Posted: 14 Mar 2023 at 7:42am
Ether like some folks use to start engines always released for me
1984 80780
1957 D14
DES 300 with 25000 engine
616 tractor
KMAG View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote KMAG Quote  Post ReplyReply Direct Link To This Post Posted: 14 Mar 2023 at 8:33am
Brake cleaner softens/destroys most silicone. Get the chorinated version - the less eco friendly the better.
Les Kerf View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Les Kerf Quote  Post ReplyReply Direct Link To This Post Posted: 14 Mar 2023 at 9:07am
Try some rubbing alcohol, it probably isn't as effective as the harsher chemicals mentioned above but isn't as nasty to work with.
