Pinion Shaft Bearing
Kevin01 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Kevin01 Quote  Post ReplyReply Direct Link To This Post Topic: Pinion Shaft Bearing
    Posted: 13 Mar 2023 at 10:04pm
Just got a 1964 I-40 Allis Chalmers tractor and I have lost the outer bearing on the axel shaft and I can’t find the s/n for the machine and I have now clue what bearing I need. Any suggestions? Thanks.
Post Options Post Options   Thanks (0) Thanks(0)   Quote DiyDave Quote  Post ReplyReply Direct Link To This Post Posted: 14 Mar 2023 at 4:44am
Welcome to the forum.  Serial number is on the the torque tube, carb side.  Same tractor as D-10/12...  Scroll down in the link for picture...Wink
Post Options Post Options   Thanks (0) Thanks(0)   Quote steve(ill) Quote  Post ReplyReply Direct Link To This Post Posted: 14 Mar 2023 at 8:47am
Ii think the I40 should be the same rear end as a D12 (?) ..... here are the part numbers, you might compare the SIZE.
Post Options Post Options   Thanks (0) Thanks(0)   Quote steve(ill) Quote  Post ReplyReply Direct Link To This Post Posted: 14 Mar 2023 at 12:27pm
Kevin, i was hoping someone with some better info would jump in here and answer.. I dont see these two ALLIS part numbers being cross referenced to a Name Brand Bearing anywhere on  GOOGLE.... Do you have an ID or an OD for the bearing... or is there a number etched on the races ?  ... If your going to an ALLIS Dealer, thats different.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Kevin01 Quote  Post ReplyReply Direct Link To This Post Posted: 14 Mar 2023 at 11:08pm
Steve,
I found the bearing I needed. I was able to pull it off the axel and get numbers off of it. So I’m a week I should have this up and running again. Thanks for the response.
Post Options Post Options   Thanks (0) Thanks(0)   Quote AC720Man Quote  Post ReplyReply Direct Link To This Post Posted: 15 Mar 2023 at 6:52am
You didn’t mention replacing the seal, perfect time to replace it. Are you replacing the axle bearing or pinion shaft bearing?
Edited by AC720Man - 15 Mar 2023 at 6:57am
Post Options Post Options   Thanks (1) Thanks(1)   Quote steve(ill) Quote  Post ReplyReply Direct Link To This Post Posted: 15 Mar 2023 at 8:22am
Kevin... when you get time, post the bearing number for others reference..
Post Options Post Options   Thanks (0) Thanks(0)   Quote Kevin01 Quote  Post ReplyReply Direct Link To This Post Posted: 21 Mar 2023 at 7:49pm
Steve,
So I put the new outer pinion bearing on and drove for about 5 minutes and totally destroyed the new bearing. Pulled the outer inspection cap off and flashed a flashlight into the axel housing and I think the inner bearing is gone. My nightmare came true and now I’m going have to pull the whole axel housing off the tractor. Fun
Post Options Post Options   Thanks (0) Thanks(0)   Quote Kevin01 Quote  Post ReplyReply Direct Link To This Post Posted: 21 Mar 2023 at 7:52pm
The part number for the bearing is (br14139) and the race is (br14276)
