Kill Switch
jshoemaker View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote jshoemaker Quote  Post ReplyReply Direct Link To This Post Topic: Kill Switch
    Posted: 13 Oct 2010 at 8:55am
I am going to add a kill switch to my WC electrical system.  At what point do I wire it in?  I would assume between the coil and what else, or am I totally off?  Also there was a solenoid on the tractor, but I am not sure I need it do I?  Thanks for all the help.
DonDittmar View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote DonDittmar Quote  Post ReplyReply Direct Link To This Post Posted: 13 Oct 2010 at 10:48am
Unless its been converted, a WC is Mag fired, it wouldnt have a coil that is external. In the case of a mag fired tractor, you need to put a switch inbetween the stud sticking out the side of the MAG and ground
1968 D15D,1962 D19D
ALinIL View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote ALinIL Quote  Post ReplyReply Direct Link To This Post Posted: 13 Oct 2010 at 10:51am
I assume you have a electric start WC with a magneto.  The original starter did not have a solenoid.  May have been added to give push  button start.  As for a kill switch, you need to have a wire attached to the same screw that the condensor wire attaches to.  To kill, this wire needs to be attached to a switch that can supply a ground.  Some of the magnetos had a kill switch on them on the LH side.  Others had a post there to attach a wire.  Hope this helps. - AL
Post Options Post Options   Thanks (0) Thanks(0)   Quote jshoemaker Quote  Post ReplyReply Direct Link To This Post Posted: 13 Oct 2010 at 12:13pm
It has been coverted to a distributor.  The soleniod sets where the original push button starter switch set on the side of the starter.  My push button starter switch is now on the foot plate under the steering wheel and my kill switch is up by my trottle cable.  Do I have you confused now?
Post Options Post Options   Thanks (0) Thanks(0)   Quote CTuckerNWIL Quote  Post ReplyReply Direct Link To This Post Posted: 13 Oct 2010 at 12:54pm
With a distributor ignition you have battery voltage supplying current to the coil. For the kill switch, you need to interrupt that supply voltage. You can add the kill switch  anywhere in between the on off switch and the coil.
Edited by CTuckerNWIL - 13 Oct 2010 at 12:55pm
Post Options Post Options   Thanks (0) Thanks(0)   Quote CTuckerNWIL Quote  Post ReplyReply Direct Link To This Post Posted: 13 Oct 2010 at 12:57pm
If you take the solenoid off, you will need to add a manual switch to supply power to the starter.
Post Options Post Options   Thanks (0) Thanks(0)   Quote ALinIL Quote  Post ReplyReply Direct Link To This Post Posted: 13 Oct 2010 at 1:49pm
It you have battery ignition, then you already have a ignition switch.  If you want to add an additional kill switch, then you need to place a power interrupt switch somewhere in series between the ignition switch and the coil. - AL
Bee View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Bee Quote  Post ReplyReply Direct Link To This Post Posted: 14 Oct 2010 at 9:12am
A good idea!
Bob, North Carolina
1949 B
