5015 Turf tires
bena18 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote bena18 Quote  Post ReplyReply Direct Link To This Post Topic: 5015 Turf tires
    Posted: 11 Mar 2023 at 10:38am
Im looking for both front and rear turf tires and wheels for a 5015. SWMO, Thanks,Ben
Fred in Pa View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Fred in Pa Quote  Post ReplyReply Direct Link To This Post Posted: 11 Mar 2023 at 11:41am
Just Sold a tractor with .Will tell the guy that bought it,
nonetheless ,still dead.
Post Options Post Options   Thanks (0) Thanks(0)   Quote bena18 Quote  Post ReplyReply Direct Link To This Post Posted: 11 Mar 2023 at 5:41pm
Thank you
Post Options Post Options   Thanks (0) Thanks(0)   Quote bena18 Quote  Post ReplyReply Direct Link To This Post Posted: 28 Mar 2023 at 8:16pm
bump
Post Options Post Options   Thanks (0) Thanks(0)   Quote bena18 Quote  Post ReplyReply Direct Link To This Post Posted: 05 Aug 2023 at 8:30am
bump
Post Options Post Options   Thanks (0) Thanks(0)   Quote steve(ill) Quote  Post ReplyReply Direct Link To This Post Posted: 07 Aug 2023 at 4:59pm
tires should be something like this.... apparently 15 inch diameter rims maybe 9 - 10 inches wide .............. do you know the bolt pattern ?
Edited by steve(ill) - 07 Aug 2023 at 5:00pm
Post Options Post Options   Thanks (0) Thanks(0)   Quote steve(ill) Quote  Post ReplyReply Direct Link To This Post Posted: 07 Aug 2023 at 5:56pm
I have no idea what your bolt pattern is, but this is a COMMON 15 inch tractor rim... Note the center hole and bolt hole pattern...
Gary Burnett View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Gary Burnett Quote  Post ReplyReply Direct Link To This Post Posted: 08 Aug 2023 at 7:03am
I have a set on a 5020 if they are the same
