Harmonic Balancer Pulley 7045, 7580
mraver View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote mraver Quote  Post ReplyReply Direct Link To This Post Topic: Harmonic Balancer Pulley 7045, 7580
    Posted: 07 Mar 2023 at 2:17pm
I recently purchased a 7045 on auction and after I cleaned it all up I noticed that the harmonic balancer pulley has some of the rubber coming out and has a small wobble. Other than that it sounds good and I think the tractor is in reasonable shape for 40+ years old. I have a parts black belly 7580 that I could pull the harmonic balancer pulley off of. I know they are not exactly the same but I wasn't sure if that would make a difference?
Can I use the pulley off the parts 7580 or should I just go buy a new one.
Thanks
Matthew
Post Options Post Options   Thanks (0) Thanks(0)   Quote SteveM C/IL Quote  Post ReplyReply Direct Link To This Post Posted: 07 Mar 2023 at 8:54pm
Doubt you can buy new. there is a guy who rebuilds the rubber ring kind. think he only works part time....like several months off. Is that 7580 the 4wd with the 426? It would have the viscous damper which may or may not be so good this many years later. Would have to change complete pulley . Don't ding the damper. Guessing belt grooves in same place?
Edited by SteveM C/IL - 07 Mar 2023 at 8:57pm
Post Options Post Options   Thanks (0) Thanks(0)   Quote mraver Quote  Post ReplyReply Direct Link To This Post Posted: 08 Mar 2023 at 4:02pm
Yes the 7580 has the same block just is running all it can put out
