D17 diesel generator cover |
Page 12> |
AC720Man
Joined: 10 Oct 2016 Location: Shenandoah, Va Points: 5478 |
Topic: D17 diesel generator coverPosted: 05 Mar 2023 at 9:48pm |
Mine is missing it, would someone take a picture and provide some measurements of the cover that goes over the generator on series 1 diesel.
Thanks in advance Rob |
AC720Man
Posted: 12 Mar 2023 at 8:18pm |
BTT, instead of me guessing a few measurements is all I’m asking for. Or a NOS would be even better. I’m trying to put this 3 bar back as original as possible. Just trying to fill in the blanks. Or a good used part will be fine.
Thanks in advance Edited by AC720Man - 12 Mar 2023 at 8:30pm |
A-C_220
Posted: 13 Mar 2023 at 11:55am |
Are you talking about the brush cover or is there another cover?
Fred in Pa
Joined: 13 Sep 2009 Location: Hanover Pa. Points: 9210 |
Posted: 13 Mar 2023 at 12:20pm |
![]() this should help a lot . ![]() ![]() Edited by Fred in Pa - 13 Mar 2023 at 12:29pm |
Jasonw
Posted: 13 Mar 2023 at 12:28pm |
I think he referring to the one pictured photo 3 of this tractor...
200Tom1
Posted: 13 Mar 2023 at 2:53pm |
What is the purpose of the Genny cover? I ran my series 4 diesel for 25 years without 1. I never knew they existed until I read this post.
AC720Man
Posted: 13 Mar 2023 at 4:17pm |
DSeries4
Joined: 12 Sep 2009 Location: Ontario, Canada Points: 7639 |
It's for the earlier models with the oil bath air cleaner directly above the generator. Presumably it's to keep any spilled oil off of the genny. Not for late models with the dry air cleaner.
AC720Man
Posted: 13 Mar 2023 at 4:20pm |
They were on the series 1, when changing the oil bath filter it prevents oil from running down on the generator, belts if someone didn’t take their time and slop oil out of the pan.
AC720Man
Posted: 13 Mar 2023 at 4:22pm |
Now that’s funny we were typing at the same time Myron
200Tom1
Posted: 13 Mar 2023 at 5:23pm |
Thanks guys
200Tom1
Posted: 13 Mar 2023 at 5:24pm |
Thanks guys
AC720Man
Posted: 16 Mar 2023 at 7:30pm |
I made a card board version and dropped it off to the machine shop. Just going by the partial picture from my manual. It won’t be original but it will be close enough.
Edited by AC720Man - 16 Mar 2023 at 7:31pm |
DCAC
Joined: 20 Oct 2018 Location: east central SD Points: 529 |
Posted: 20 Mar 2023 at 6:08pm |
Did anyone find an original one of these, or be willing to take pics and measurements of one? I could use one too, mine's gone.
AC720Man
Posted: 20 Mar 2023 at 7:27pm |
Apparently most were tossed aside but it’s actually a functional part that protects the generator. I didn’t get any response, I hope you do. If not, I will post what I am having made when it’s completed.
DCAC
Posted: 20 Mar 2023 at 7:39pm |
Sounds good, Robbie, thanks! Maybe one will turn up on a tractor at a show, and perhaps the owner would be kind enough to let one of us get some measurements. I believe mine is a '60 model, if I remember correctly. Would you know if the wide fronts are different across the series of D17's, and between gas and diesel? My wide front has been a little modified.
DCAC
Posted: 20 Mar 2023 at 7:51pm |
The guy you got your shroud from didn't have the gen cover?
AC720Man
Posted: 20 Mar 2023 at 9:57pm |
He had already parted out the rest of the tractor and the shroud and grill was all he had left. I’m not sure about the WF, but as far as the power steering ,changes occurred several times over the series.
Edited by AC720Man - 20 Mar 2023 at 9:59pm |
AC720Man
Posted: 20 Mar 2023 at 10:01pm |
What’s your serial number Kevin?
DCAC
Posted: 20 Mar 2023 at 10:09pm |
I don't remember, I'll check tomorrow and report back,
DCAC
Posted: 21 Mar 2023 at 8:00pm |
29586
AC720Man
Posted: 21 Mar 2023 at 8:31pm |
You do in fact have a late series 1, 1960.
DCAC
Posted: 21 Mar 2023 at 8:58pm |
My neighbor has an early 17, not sure if it's a diesel though. I'll stop in and find out for sure, if so, I'll see if i can get some pics and dimensions,
DCAC
Posted: 21 Mar 2023 at 8:59pm |
Of the gen cover.
AC720Man
Posted: 21 Mar 2023 at 9:00pm |
That would be great! Thanks
AC720Man
Posted: 21 Mar 2023 at 9:04pm |
It will have to be a diesel to have one. Gas versions had the air filter at the left rear of the engine.
DCAC
Posted: 21 Mar 2023 at 9:12pm |
, I've only seen it from the road when he has all his Allis's sitting outside on a holiday weekend, I can ask his SIL too.
Bill Deppe/AC Salvag
Joined: 12 Sep 2009 Location: Maquoketa, Iowa Points: 976 |
Posted: 22 Mar 2023 at 10:21am |
Finally found several of these covers that I had replicated several years ago. They were done from an original. If still looking, let me know 563 357 2615 Can send pictures via text
DCAC
Posted: 22 Mar 2023 at 6:51pm |
PM sent
AC720Man
Posted: 22 Mar 2023 at 7:48pm |
Thanks Bill, I sent you a text
Page 12> |
