D19 Carb issues
53D17 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote 53D17 Quote  Post ReplyReply Direct Link To This Post Topic: D19 Carb issues
    Posted: 28 Feb 2023 at 6:04pm
Howdy y’all, I recently purchased a D19 gas with a Marvel Schebler TSX848 carb. I rebuilt the carb and am now having issues with it dying when I push the choke off and the carb frosts after running for a few minutes. I’ve pulled it apart and checked everything over a few different times and can’t find any channels plugged or any leaks. Thanks for the help.
Post Options Post Options   Thanks (0) Thanks(0)   Quote DrAllis Quote  Post ReplyReply Direct Link To This Post Posted: 28 Feb 2023 at 6:16pm
Open the main jet screw several turns. You shouldn't have to run with the choke on to keep it running.
Post Options Post Options   Thanks (0) Thanks(0)   Quote 53D17 Quote  Post ReplyReply Direct Link To This Post Posted: 01 Mar 2023 at 4:55pm
Tried opening it tonight and it went 2 full turns then went to a rough idle and died
EDIT, took the screw out a couple more turns. And it runs like a top now
Edited by 53D17 - 01 Mar 2023 at 4:59pm
HudCo View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote HudCo Quote  Post ReplyReply Direct Link To This Post Posted: 01 Mar 2023 at 7:43pm
out 4 turns seems like alot you may have opened it enought to pash some junk through and you could possibly turn it back in a turn or two , as you will use alot of gas.  right or wrong i was tuaght to rapidly go from idle to wide open throttle and turn it back in until their was alittle hesitation then open back just enought to make the hesitation go away when you whent from idle to wide open,   and that  would get the best power and fuel economy
This page was generated in 0.065 seconds.
