Slow hydraulics
mikeyD View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote mikeyD Quote  Post ReplyReply Direct Link To This Post Topic: Slow hydraulics
    Posted: 28 Feb 2023 at 4:48pm
They used to raise my 3-point fast enough that I did not have to slow down to lift my disc and turn.
Now I have to stop and after about 3 seconds they start slowly raising.
Any ideas would be appreciated.
Post Options Post Options   Thanks (0) Thanks(0)   Quote DiyDave Quote  Post ReplyReply Direct Link To This Post Posted: 28 Feb 2023 at 5:21pm
Start with the basics, have you checked fluid level?
You didn't mention the tractor model, also if it has one, have you changed the filter and oil recently?
Post Options Post Options   Thanks (0) Thanks(0)   Quote Tracy Martin TN Quote  Post ReplyReply Direct Link To This Post Posted: 28 Feb 2023 at 5:22pm
What tractor? What other symptoms? Tracy
Post Options Post Options   Thanks (0) Thanks(0)   Quote steve(ill) Quote  Post ReplyReply Direct Link To This Post Posted: 28 Feb 2023 at 5:28pm
this time of year, a little water contamination can freeze and cause little ICE CHUNKS that cause problems in the pump... You could pull the drain plug and drain out a quart and get an idea of what the oil condition is..
Edited by steve(ill) - 28 Feb 2023 at 5:29pm
Post Options Post Options   Thanks (0) Thanks(0)   Quote mikeyD Quote  Post ReplyReply Direct Link To This Post Posted: 28 Feb 2023 at 5:36pm
DiyDave - fluid level good...Allis C and Ford NAA...no filter or oil change
Tracy - no other symptoms
steve(ill) - that is what i will try next
Thanks all for replies.
Post Options Post Options   Thanks (0) Thanks(0)   Quote PaulB Quote  Post ReplyReply Direct Link To This Post Posted: 28 Feb 2023 at 6:28pm
The Allis C doesn't have a filter or even a screen on the pump inlet, unless one has been added at some time. Cruddy oil can gum up the check ball in the pump. I goo flush of the transmission/PTO/Hydraulic pump is the first and easiest thing to do.
 The Ford should have a screen on the inlet down inside of the transmission case. Sometime you can back flush it by removing the tube from the transmission to the pump. Cruddy oil is most likely your problem here as well.
Tbone95 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Tbone95 Quote  Post ReplyReply Direct Link To This Post Posted: 01 Mar 2023 at 6:38am
Wait, so it's doing it on 2 different tractors beginning at the same time?
plummerscarin View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote plummerscarin Quote  Post ReplyReply Direct Link To This Post Posted: 01 Mar 2023 at 11:43am
Implement hydraulic couplers if symptom is same for both tractors?
Post Options Post Options   Thanks (0) Thanks(0)   Quote mikeyD Quote  Post ReplyReply Direct Link To This Post Posted: 01 Mar 2023 at 6:31pm
PaulB - Thanks, will change fluids in both tractors
Tbone95 - yeah, the allis was just slow, now wont lift at all
plummerscarin- not quite sure what you mean
Thanks, all for responses
Post Options Post Options   Thanks (0) Thanks(0)   Quote plummerscarin Quote  Post ReplyReply Direct Link To This Post Posted: 01 Mar 2023 at 6:44pm
Wrong train of thought. Never mind me
Post Options Post Options   Thanks (0) Thanks(0)   Quote Tbone95 Quote  Post ReplyReply Direct Link To This Post Posted: 01 Mar 2023 at 10:00pm
The way you answered the one question about which tractor, you made it sound like the Allis and the Ford had slow hydraulics   Possibly. That’s what Plummer and I were trying to clarify.
Post Options Post Options   Thanks (0) Thanks(0)   Quote plummerscarin Quote  Post ReplyReply Direct Link To This Post Posted: 01 Mar 2023 at 10:15pm
I re read OP and saw him say 3pt. But then later said 2 tractors with same problem so thought pull type with hydraulic cylinder
Need clarification now
Post Options Post Options   Thanks (0) Thanks(0)   Quote Tbone95 Quote  Post ReplyReply Direct Link To This Post Posted: 02 Mar 2023 at 6:32am
I guess I forgot about 3 point. The two tractors comment threw me off and I was thinking cylinder as well.
