D 15 front tires Update
ACinSC View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote ACinSC Quote  Post ReplyReply Direct Link To This Post Topic: D 15 front tires Update
    Posted: 28 Feb 2023 at 12:44pm
Plan to go from 6.50/16 to 7.50/16 loaded tires to help keep my front end on the ground . Old tires are 6 ply , new ones are 12 ply . That shouldn't be a problem , should it ? THANKS !
Edited by ACinSC - 03 Mar 2023 at 1:26pm
Post Options Post Options   Thanks (0) Thanks(0)   Quote steve(ill) Quote  Post ReplyReply Direct Link To This Post Posted: 28 Feb 2023 at 3:54pm
ii bought 14 ply x 16 inch tires for the front of the backhoe and i could not get them on the rim with "my" tools... had to go to the tire shop and have them install... He said no problem.... operations wise, there is no problem.
Post Options Post Options   Thanks (0) Thanks(0)   Quote ACinSC Quote  Post ReplyReply Direct Link To This Post Posted: 28 Feb 2023 at 4:03pm
Thanks Steve. Almost seems like the more plys the better on a tractor tire ?
Post Options Post Options   Thanks (0) Thanks(0)   Quote steve(ill) Quote  Post ReplyReply Direct Link To This Post Posted: 28 Feb 2023 at 4:07pm
more plys gives more load capacity and more puncture resistance.... load depends on the rims you have.... nothing wrong with 12 ply tires... just TOUGH to flex them onto the rims.
Post Options Post Options   Thanks (0) Thanks(0)   Quote DrAllis Quote  Post ReplyReply Direct Link To This Post Posted: 28 Feb 2023 at 5:37pm
I wouldn't be surprised if a 7:50 x 16 tire would rub on the steering arm at the top. I don't think that size of tire was ever offered on a D-15. A 6 bolt hub might be better than a 5 bolt hub for clearance.
Post Options Post Options   Thanks (0) Thanks(0)   Quote ACinSC Quote  Post ReplyReply Direct Link To This Post Posted: 28 Feb 2023 at 8:58pm
According to my book 7.50/16 was an option. Guess I'll find out if it rubs. Thanks
DSeries4 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote DSeries4 Quote  Post ReplyReply Direct Link To This Post Posted: 01 Mar 2023 at 3:38pm
My neighbor's D15 II had 7.50 x 16 on the front 5 bolt rims before I restored it.  12 Ply for a 7.50 x 16 is crazy!  They will not have any flex at all.  The only 12 ply tires I have are 24.5 x 32s on my D21.
Post Options Post Options   Thanks (0) Thanks(0)   Quote ACinSC Quote  Post ReplyReply Direct Link To This Post Posted: 01 Mar 2023 at 5:39pm
Yeah Myron, seems kinda crazy to me too. Hope to get them back tomorrow and go for a test drive
Thanks
captaindana View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote captaindana Quote  Post ReplyReply Direct Link To This Post Posted: 01 Mar 2023 at 6:00pm
Well my Goodyears on the beech jets are 16 ply and good for 210 mph…..🤣
Blue Skies and Tail Winds
                          Dana
Post Options Post Options   Thanks (0) Thanks(0)   Quote ACinSC Quote  Post ReplyReply Direct Link To This Post Posted: 02 Mar 2023 at 11:03am
THANKS Dana , my old D 15 probably will only go about 15 mph and I hope the tires stay on the ground .
Post Options Post Options   Thanks (0) Thanks(0)   Quote ACinSC Quote  Post ReplyReply Direct Link To This Post Posted: 03 Mar 2023 at 1:31pm
Have my new tires on . Old unloaded 6.50/16 tires weighed about 55 lbs each . New tires weigh about 130 lbs . Should help keep my front tires on the ground ? Be a while before I'm back at the 'farm'to find out. These tires are 8 ply . Dunno why they told me 12 . Almost forgot , tires don't rub on anything . Thanks !
Edited by ACinSC - 03 Mar 2023 at 6:44pm
BobPaulusCentrOH View Drop Down
Bronze Level Access
Bronze Level Access
Post Options Post Options   Thanks (0) Thanks(0)   Quote BobPaulusCentrOH Quote  Post ReplyReply Direct Link To This Post Posted: 04 Mar 2023 at 5:59pm
I have that size on my D-15 Series 2.  8 ply and real strain to mount on rims.
Glad they fit.
Bob
Post Options Post Options   Thanks (0) Thanks(0)   Quote ACinSC Quote  Post ReplyReply Direct Link To This Post Posted: 05 Mar 2023 at 10:58am
Yeah Bob , bet 12 ply would've really been hard to put on the wheels . Kinda glad they wound up being 8 ply . Dr Allis was right about the tires being close to the control arm . I'm happy they don't rub . Does your Series 2 have 6 bolt hubs ? Just curious . Thanks !
Bronze Level Access
Bronze Level Access
Post Options Post Options   Thanks (0) Thanks(0)   Quote BobPaulusCentrOH Quote  Post ReplyReply Direct Link To This Post Posted: 05 Mar 2023 at 4:08pm
No, my D15 has 5 bolt wheels and hubs.
I have a D15 Diesel Tractor Loader Backhoe that is 5 lug wheels and hubs, also.
Post Options Post Options   Thanks (0) Thanks(0)   Quote ACinSC Quote  Post ReplyReply Direct Link To This Post Posted: 05 Mar 2023 at 8:27pm
Ok thanks Bob!
Post Options Post Options   Thanks (0) Thanks(0)   Quote ACinSC Quote  Post ReplyReply Direct Link To This Post Posted: 09 Mar 2023 at 3:26pm
New tires have 0423 date code . I'm thinking that means they were made the 4th week of this year ? Seems I read somewhere that it takes new tires a while to 'toughen up'? Anyone know if that's right and how long ? Thanks !
Post Options Post Options   Thanks (0) Thanks(0)   Quote jaybmiller Quote  Post ReplyReply Direct Link To This Post Posted: 09 Mar 2023 at 3:39pm
0423 could be 23rd week of 2004 ?Cry
I'd keep couple extra PSI for a few hours of use, just to help 'seat' rubber to rim.
Post Options Post Options   Thanks (0) Thanks(0)   Quote steve(ill) Quote  Post ReplyReply Direct Link To This Post Posted: 09 Mar 2023 at 3:51pm
The last four numbers represent the manufacturer's date. The first two numbers indicate the week, while the last two indicate the year. (For example, a tire with the number 2910 was manufactured in the 29th week of 2010.)
Post Options Post Options   Thanks (0) Thanks(0)   Quote ACinSC Quote  Post ReplyReply Direct Link To This Post Posted: 09 Mar 2023 at 7:48pm
Thanks Jay and Steve.
200Tom1 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote 200Tom1 Quote  Post ReplyReply Direct Link To This Post Posted: 09 Mar 2023 at 11:23pm
ACinSC. You are right, it takes a while for them toughen up. Id stay outta the cornstalks/bean stubble for a month or so. When I owned my tire shop, we had a big fenced in back lot. We ordered semi loads of rears, had them delivered as close to Jan 1st as we could. They set out there for 30-45 days before we actively started selling them. I can not remember ever having trouble with fronts.
Post Options Post Options   Thanks (0) Thanks(0)   Quote ACinSC Quote  Post ReplyReply Direct Link To This Post Posted: 10 Mar 2023 at 6:14am
Thanks Tom. Good to know!
