4 Section Snap Coupler Rotary Hoe
wjohn View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote wjohn Quote  Post ReplyReply Direct Link To This Post Topic: 4 Section Snap Coupler Rotary Hoe
    Posted: 25 Feb 2023 at 9:22pm
I had to outbid a lady who wanted to do crafty things with all the wheels, but I managed to bring home a Snap Coupler rotary hoe today.
A couple of the vertical supports are broken, and some of the wood bearing blocks need attention. It should make a good addition for early weed control after planting. I'll probably have to add some weight to the front of my WD or WD-45 to keep the front end on the ground when I pick it up?
rtwfarm View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote rtwfarm Quote  Post ReplyReply Direct Link To This Post Posted: 25 Feb 2023 at 10:05pm
I have a parts one
Post Options Post Options   Thanks (0) Thanks(0)   Quote SteveM C/IL Quote  Post ReplyReply Direct Link To This Post Posted: 25 Feb 2023 at 11:21pm
You ARE going to want some added weight!
Lars(wi) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Lars(wi) Quote  Post ReplyReply Direct Link To This Post Posted: 26 Feb 2023 at 1:04am
I recall, for those to work properly your ground speed had be near road gear. We had a 3 point mount on an IH 826, used high range 3rd gear TA forward, throttle near wide open. Would a WD-45 have enough power go fast enough?
captaindana View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote captaindana Quote  Post ReplyReply Direct Link To This Post Posted: 26 Feb 2023 at 4:39am
I’d love to see these in action!
Blue Skies and Tail Winds
                          Dana
plummerscarin View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote plummerscarin Quote  Post ReplyReply Direct Link To This Post Posted: 26 Feb 2023 at 7:33am
That's how I remember it. Dad said to use road gear. Would have been nice if there had been a shield to protect the operator. With the 262 gas engine up front on the repowered WD I don't recall weights being used though he did have a bracket fabbed for suitcase weights.
Glad you outbid the craft lady. My accountant wants to do same with one in the weeds behind the barn. It is not an Allis at least
nickia View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote nickia Quote  Post ReplyReply Direct Link To This Post Posted: 26 Feb 2023 at 8:52am
they are even heavy on a d-17
IBWD MIke View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote IBWD MIke Quote  Post ReplyReply Direct Link To This Post Posted: 26 Feb 2023 at 9:05am
Nice save.
darrel in ND View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote darrel in ND Quote  Post ReplyReply Direct Link To This Post Posted: 26 Feb 2023 at 10:05am
Glad that it's going to a good home
Darrel
Gatz in NE View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Gatz in NE Quote  Post ReplyReply Direct Link To This Post Posted: 26 Feb 2023 at 10:53am
Back in the 60's, the IHC rotary hoe we had was pulled conventionally with the drawbar on our D17 Diesel.  We made a SC carrier from some bridge planks to transport it over roads to other fields.  The carrier with the RH weighed quite a lot and made the front end so light, we had to have one person stand on the front axle to keep it down when crossing a shallow creek.
(The SC lift arms of the D17 were "substantial" to say the least and up to the task )
To get around this problem, Dad and I made a Snap Coupler mount for the rotary hoe.
The SC lift for the rotary hoe had eight "arms" that were welded to a long steel tube from which the 4 gangs were suspended.
Another tube was welded at 90º on center and had a loop to engage the SC hook.
Links were attached to the main tube to connect with the SC arms.  It worked great.
A neighbor wanted one for his IHC 706, so we made one for him.  However, this time we decided to use only 4 arms, but still used chains to suspend the gangs
The D17 pulled the rotary hoe with ease in 3rd direct, but if the field sloped just enough, I could get it going in 4th under; then shift down to 3rd direct again without stopping before a turnaround...it just took a little practice to coordinate the transmission shift + the PD shift at the same time to avoid any clashing; it just easily slipped into gear.
Very nice sunny late spring days.
Edited by Gatz in NE - 26 Feb 2023 at 10:53am
Allis dave View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Allis dave Quote  Post ReplyReply Direct Link To This Post Posted: 01 Mar 2023 at 7:28am
I have one just like it except it's hydraulic fold. I haven't gotten to use it yet, but I hope to get it out fro an Allis show this year. Mine came with a couple new woods block so I got some Poly material from MCMasterCarr to make new bearing block. Made some but never finished the project.
orangereborn View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote orangereborn Quote  Post ReplyReply Direct Link To This Post Posted: 02 Mar 2023 at 5:35pm
I have a drag type and it sits on a Allis Implement trailer. I never could make it work and sounds like I need to jump up a gear or so.  Have some organic growers really do a great job with them.  They have the 3 PT and say they are tempermental but tilting them forward or back usually does the job. But the next day the same field may different....I could not even make dust....
Edited by orangereborn - 02 Mar 2023 at 5:36pm
Clay View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Clay Quote  Post ReplyReply Direct Link To This Post Posted: 02 Mar 2023 at 5:54pm
You can make bearing blocks out of OAK or MAPLE.  Either work well.
Depending upon the diameter and length, it might be possible to use straw walker bearing blocks.
