210 engine rebuild on youtube what went wrong
rieg View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote rieg Quote  Post ReplyReply Direct Link To This Post Topic: 210 engine rebuild on youtube what went wrong
    Posted: 25 Feb 2023 at 10:21am
Great rebuild, very good machine shop, an interesting father and son team, very interesting channel but something went south will need to watch part two and maybe three to find out. Part three is not out yet. Maybe you guys can help figure out what went wrong?? This is the title of the video, sorry I don't know how to link it.
This Is Why You Don't Want To Buy A $500 Allis Chalmers Two-Ten Tractor...
rieg
Post Options Post Options   Thanks (0) Thanks(0)   Quote Mikez Quote  Post ReplyReply Direct Link To This Post Posted: 25 Feb 2023 at 11:14am
Look under 220 engine rebuild video.
Post Options Post Options   Thanks (0) Thanks(0)   Quote steve(ill) Quote  Post ReplyReply Direct Link To This Post Posted: 25 Feb 2023 at 11:54am
Post Options Post Options   Thanks (0) Thanks(0)   Quote steve(ill) Quote  Post ReplyReply Direct Link To This Post Posted: 25 Feb 2023 at 11:55am
jvin248 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote jvin248 Quote  Post ReplyReply Direct Link To This Post Posted: 25 Feb 2023 at 1:38pm
I saw that 2nd video earlier today, comments under the video lead to conclusion the fuel injector timing was set wrong when the injector system was rebuilt. So when using that system to time the engine they were off.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Mikez Quote  Post ReplyReply Direct Link To This Post Posted: 25 Feb 2023 at 1:52pm
Go to the other post 220 engine rebuild. Dr has good reasoning
B26240 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote B26240 Quote  Post ReplyReply Direct Link To This Post Posted: 25 Feb 2023 at 3:28pm
I'll put my money on what Dr allis said about piston skirt clearance !!
Post Options Post Options   Thanks (0) Thanks(0)   Quote DrAllis Quote  Post ReplyReply Direct Link To This Post Posted: 25 Feb 2023 at 3:43pm
They did NOT come to the conclusion there was anything wrong with the "static" injection pump timing. They checked the crank pulley clocking and inj pump static timing mark and all was acceptable. There still could be a problem with the automatic timing advance and they are having the inj pump re-checked for that. I'd think in the next 30 days or so we should hear what the problem was, as he uses this tractor in the field.
Ed (Ont) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Ed (Ont) Quote  Post ReplyReply Direct Link To This Post Posted: 25 Feb 2023 at 5:58pm
Do you have any more of those $500 210's? Can I have ten of them? Lol. Smile
injpumpEd View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote injpumpEd Quote  Post ReplyReply Direct Link To This Post Posted: 26 Feb 2023 at 12:16pm
My money is still on fuel pump mis-assembled, so timing mark in the pump is in wrong spot. It was already proven to be wrong, and being a DC it is critical to understand where the weight carrier goes on the splined rotor. In the video when it was chiseling, it seemed to have a lot of diesel knock or rattle going through the field.
