D10 D12 fuel line?
Post Options Post Options   Thanks (0) Thanks(0)   Quote Tracy Martin TN Quote  Post ReplyReply Direct Link To This Post Topic: D10 D12 fuel line?
    Posted: 11 Oct 2010 at 9:49pm
What type of fittings were on original fuel lines? Were they flare,inverted flare or compression ? Thanks Tracy Martin
Dusty MI View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Dusty MI Quote  Post ReplyReply Direct Link To This Post Posted: 12 Oct 2010 at 7:22pm
Tracy, it appears they are inverted flare.
How are you doing on the molds for shock absorbers for the shaft coupling?
Dusty
Post Options Post Options   Thanks (0) Thanks(0)   Quote Tracy Martin TN Quote  Post ReplyReply Direct Link To This Post Posted: 12 Oct 2010 at 10:14pm
Dusty, Almost half way thru process. Will try to send your NOS back this week. Thanks for your help with this project. My fuel line has a compression fitting. Was wondering what were on most out there. I am sure it could have been replaced. Thanks Tracy Martin
Post Options Post Options   Thanks (0) Thanks(0)   Quote Dusty MI Quote  Post ReplyReply Direct Link To This Post Posted: 13 Oct 2010 at 5:53pm
My parts book shows a 90* fitting at the carburetor and a straight fitting at the sediment bowl, 1/8" pipe to 1/8" tubing. It doesn't say they are they are inverted flare but that's what they are.  An old friend always referred to them as navy flares.
Dusty
Chalmersbob View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Chalmersbob Quote  Post ReplyReply Direct Link To This Post Posted: 13 Oct 2010 at 9:24pm
They are inverrted flares as on steel brake lines.
 All of the gas lines were steel. Brake line is very bendable when it is new. Bob
Post Options Post Options   Thanks (0) Thanks(0)   Quote Steve in NJ Quote  Post ReplyReply Direct Link To This Post Posted: 15 Oct 2010 at 6:50am
Not sure on a D10-12 machine, but all the original ones I've had on my tractors were compression type fittings. Coarse, they're gravity fed, so not much psi on the fittings. Lots of vibration though. When I make the upgrade fuel lines I sell, I then go to inverted flare with the correct fittings to make the kit...
Post Options Post Options   Thanks (0) Thanks(0)   Quote Tracy Martin TN Quote  Post ReplyReply Direct Link To This Post Posted: 16 Oct 2010 at 8:36am
Steve, That was what was on mine. I just ain't a fan of compression fittings either. Thanks Tracy Martin
